changing fuel filter, help!
Old May 27, 2005 | 02:28 PM
L33T35T 4Runner's Avatar
Lightbulb changing fuel filter, help!
ok. according to this article http://www.4x4wire.com/toyota/mainte...6/fuel_filter/ it says i can pull the fuel pump fuse. where the bejesus is that!??!?!
95 4runner
3.0l v6
auto
4x2
help pleaseeee
Old May 27, 2005 | 02:37 PM
Glenn's Avatar
In the fuse block in the engine compartment?
Old May 27, 2005 | 02:57 PM
Steveh29's Avatar
I change my filter every 30,000 miles and I've never pulled this fuse. What I do is open the gas cap to relieve any pressure in the tank and then slowly loosen the lines going into the filter. A small amount of gasoline will trickle out as you crack open the first line, so just place a little bucket below the filter. After a minute or two it'll have drained and you can remove the filter. No big deal.
Old May 27, 2005 | 03:09 PM
thanks steve. i'll try this
Old May 27, 2005 | 03:46 PM
Scofco's Avatar
Never done the fuse either, just do as Steve says.
Old May 27, 2005 | 04:33 PM
the filter decided it just didnt want to come off. i didnt want to round off the nuts, so im just gonna bite the bullet, bend over, grab some ky or astroglide, and let toyota do it
Old May 27, 2005 | 04:38 PM
calrockx's Avatar
what about trying some liquid wrench or something? whatever they do to get it off you most likely can as well.
and when i changed my fuel filter, i didn't pull any fuse either.
Old May 27, 2005 | 04:59 PM
Scofco's Avatar
Liquid wrench overnight, then grab the filter with your hand while a wrench is on one side and just reef on it. You'll get 'er.
I was just talking to someone today about how much of a PITA it is
Old May 27, 2005 | 05:23 PM
Glenn's Avatar
Tom and Ray just had a column in "Car Talk" about fuel filters having threadlocking compound put on their threads. That might be your issue.
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
Fundy Rider
Jul 16, 2015 01:35 AM
nick b
Jul 11, 2015 04:38 AM
