changing antifreeze
Old Feb 22, 2011 | 12:20 PM
ugabulldog's Avatar
changing antifreeze
i am looking in my Haynes manual and it says to remove the radiator drain plug and an engine block drain plug...... I don't remember removing the engine block drain plug last time..... is this needed and if so where is it??? thanks
Old Feb 22, 2011 | 12:28 PM
justin_4runner's Avatar
its not really needed to remove it, if u pull the theromstat it will drain most of the water out of the block. or just leave it and refill.
Old Feb 23, 2011 | 07:24 PM
skjos's Avatar
This picture was taken from the passenger side wheel well, it shows the block drain port, the drain bolt is right above it. Install some tubing on the drain port, route it into a bucket, then turn the drain bolt until the coolant flows out the tubing.
Picture with the tube installed on the port with the drain bolt above it.
Old Feb 25, 2011 | 04:09 PM
Ron Helmuth's Avatar
very helpful photo skjos
appreciate that very much
krimsonone
Sep 13, 2024 09:33 AM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
accuracy
Aug 4, 2015 08:05 PM
kcaudill
Jul 20, 2015 12:06 PM
Jonny246
Jul 12, 2015 04:51 AM
