Center Console Removal
Old May 20, 2004 | 06:39 AM
Brett605's Avatar
Question Center Console Removal
I'm installing a CD changer and I need to get to the radio cassette controller. Does anyone knows of center console removal documentation for the 3rd generation model? So I can do it safely? Thanks in advance...
Old May 20, 2004 | 10:28 AM
Phisherman's Avatar
Pull the e-brake up. Remove the screw on each side. Remove the two bolts inside on the bottom. You might need to pry up the shifter trim piece. I think that's it.
Jim
Old May 20, 2004 | 10:33 AM
rimpainter.com's Avatar
You also need to pry out the panel by the fan controls. Then you need to remove the phillips screws. Now you can pull the whole thing out. Dont forget to unplug everything from the back once it is pulled out.
Old May 20, 2004 | 10:38 AM
CLin9383's Avatar
https://www.yotatech.com/~corey/tech/slc_stereo/slc.htm
i know it's for the early 3rd gens, but it shouldn't vary that much...good luck
Old May 20, 2004 | 12:02 PM
Brett605's Avatar
Smile
alright, thanks for the info...
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
scooba
Aug 25, 2015 09:49 AM
terminator
Jul 27, 2015 07:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
HookahRoo
Jul 20, 2015 07:06 PM
