CEL again. Code P0446.
Old Mar 19, 2009 | 08:46 AM
broknlgs24's Avatar
replacing the VSV worked for my issue.
Old Mar 19, 2009 | 03:04 PM
SWPERIC's Avatar
sorry for the noobness. what does VSV stand for?
Old Mar 19, 2009 | 07:21 PM
TheDurk's Avatar
VSV = Vacuum Switching Valve. I had to look it up in the FSM myself.
Old Mar 20, 2009 | 08:04 AM
97ltd4x4's Avatar
I think one of two things are going on with this code.Either pieces of charcoal break free from canister and float in system causing a blockage in the VSV,or the VSV goes electrically open,or the VSV works but cannot seal properly internally...Most of the time the VSV sticks,But before you replace the VSV inspect the hoese very carefully for floating pieces of charcoal..If there are any small pieces,you will need to replace the charcoal assy.
online pricing:
96-2000,canister under hood
part #:2586075140
Emission system - Emission components - Vacuum valve
Vacuum valve - 3.4 liter 1996-2000 1996 - 2000 $53.94
2001-2002,canister at tank
Cannot find part number..#2 in pic.
Vacuum valve - 3.4 liter 2001-02 - 3.4 liter 2001-02
01-02 $36.52
Old Mar 23, 2009 | 11:41 AM
  #25
SWPERIC's Avatar
its a major bummer that none of these links and pics work any more. just got a quote from the stealer. the VSV is $60 and the canister is $400! i guess i will try replacing just the valve and hope that works. any write ups with working pix would be appreciated. thanks.
Old Mar 24, 2009 | 05:10 AM
  #26
97ltd4x4's Avatar
You are going to need to remove the canister and replace the VSV with the canister on the bench,should be held onto the canister with either a 10mm or phillips screw(gonna be tight,use good screwdriver and body weigh to limit cam-out)..Just mark where all the hoses go and it should go smoothly...
BTW.. can you post the VSV part# for the canister(2001-2002)?
Old Apr 12, 2009 | 06:59 PM
  #27
SWPERIC's Avatar
i have the part # on the bench in the garage. ill get it 2morrow. i am waiting for warmer weather and maybe a pic of what this thing looks like. yotatech spoils me so much. im sure once i start lookin ill find it.
Old Apr 14, 2009 | 05:15 AM
  #28
stir_fry_boy's Avatar
I agree, it would sure be nice to get a write up of the charcoal canister, possible clean out, and VSV replacement for the 01-02 by the gas tank. So many hoses!
Old Apr 14, 2009 | 06:01 AM
  #29
mt_goat's Avatar
I'm using a canister from a 93 truck with my 2001 5VZFE and no CEL. This is how its connected for anyone interested:
If you need a bigger view click the pic and select the full size option
Old Apr 14, 2009 | 06:59 AM
  #30
Mt. Goat, Which VSVs are the ones by the EGR? Vapor Pressure VSV and ??
Old Apr 14, 2009 | 07:03 AM
  #31
mt_goat's Avatar
EGR? I don't have EGR
Old Apr 14, 2009 | 07:08 AM
  #32
Does the 5VZ-FE have an EGR or did you just not put one in?
Old Apr 14, 2009 | 07:39 AM
  #33
mt_goat's Avatar
Well the very first year or 2 (like 96) may have had it, but not my 2001.
Old Apr 14, 2009 | 08:02 AM
  #34
SWPERIC's Avatar
goat, that diagram will help a lot. ive read a few post about the canister being located somewhere under the truck on some model years. can you point me to the general area where your canister is? is your VSV below the canister as documented by others? thanks for the help!
Old Apr 14, 2009 | 10:17 AM
  #35
mt_goat's Avatar
goat... can you point me to the general area where your canister is? is your VSV below the canister as documented by others? thanks for the help!
Here's my 93 truck, the canister (can) is still in the factory location. The 2001 5VZ VSVs are installed on the firewall:
Old Apr 14, 2009 | 11:43 AM
  #36
Onroadrunner, I just talked to the dealer, as far as our years (01, 02) they said that the VSV they usually replace is in the rear just in front of the spare tire. Those under the hood they don't stock. They told me that they usually are not the problem as far as VSVs are concerned. The ones in the engine bay were about $20 more each than the one in the rear. The canister is also under the vehicle, in the rear in front of the spare tire. Just FYI
Old Apr 14, 2009 | 01:57 PM
  #37
SWPERIC's Avatar
thanks! looks like tomorrow or thursday should be warm enough to get under there. i will post results.
Old Apr 19, 2009 | 03:29 PM
  #38
SWPERIC's Avatar
all who think this crazy thing is my charcoal canister, say aye! its the only thing just under the front side of my spare location that looks like it could b it.
Old Aug 7, 2009 | 08:09 PM
  #39
SWPERIC's Avatar
for my 2002 4runner. 90910-12264 was the part number. the pic above IS the charcoal canister
Old Aug 11, 2009 | 07:26 PM
  #40
X2 on PITA to get out! It took me about 1 hour to untangle the wire to the VSV for VPS and to find the clip holding 4 hoses up between the crossmember on the frame and the rear diff (only higher than the diff). But after I figured out how to do it, I replaced the canister in under 1 hour.
Good as new!
