CB SWR interpretation
Old May 6, 2003 | 06:57 AM
mtnbkr's Avatar
I finally got around to installing my CB (been busy with life lately). I installed a Radio Shack copy of the Uniden 510 radio into the ashtray space. For power, I hooked up to the power (non-switched, always "hot") and ground leads coming from the aftermarket radio harness (hooked in prior to radio's fuse on + side, the "Chassis ground lead was unused, so I used it). The antenna is a 4' Silver Load Flex mounted to a modified mirror mount bolted to the front brushguard (antenna clears roof by 3"-4"). I did not hook any ground wires from the antenna mount to the brushguard or body (forgot actually). I used 12' of coax cable.
When I tested the SWR, I was able to tune it down to 1:1.4 for Channels 1 and 40 and 1:1.3 for Channel 20. With the truck off, the reception is crystal clear. With the truck running, there is a touch of static to incoming signals, but it does not sound like alternator whine, more like general static.
Should I change anything? Do I need the ground wire? The antenna also has a wire lead coming from it. I was told not to use that unless I can't get the SWR low enough.
thanks,
Chris
Old May 6, 2003 | 07:34 AM
seafarinman's Avatar
Sounds like it is just perfect to me. You seem to have aconsistent reading on channels 1,20, and 40. I would leave it alone.
Old May 6, 2003 | 08:17 AM
mtnbkr's Avatar
That was what I thought, but I kept reading about hooking up ground wires and such. I wanted to make sure it was correct before I needed it.
Thanks,
Chris
msged2007
Aug 22, 2015 07:46 PM
BajaRunner
Jun 12, 2006 02:29 PM
Old Red
Oct 9, 2005 02:10 PM
