Can't Shut Off My Car Alarm - Help!!
Old Mar 19, 2004 | 11:16 AM
PBR_Streetgang's Avatar
I don't know much about car alarms, but I had to leave my 4runner in a parking lot last night because I couldn't disarm the alarm. It turns off by itself, after a minute, but the engine won't fire.
Is there a fuse that I can pull to disable the alarm? If I disconnect the battery and reconnect, will that work?
I also can't find the swith inside the car (installed by 1st owner).
Many thanks
Old Mar 19, 2004 | 11:28 AM
MTL_4runner's Avatar
No, you need to disarm using the remote or remove the alarm completely.
If it were that easy, thieves would have a field day.
Old Mar 19, 2004 | 11:31 AM
NX Tacoma's Avatar
If you disconnect the battery and then reconnect it, it will only sound the alarm again. You need to find the switch(button) and hold it down for 3 second then start it. It will reset the alarm and it should be ok.
NX Tacoma
Old Mar 21, 2004 | 02:37 PM
User 051420's Avatar
On some alarms (like mine) there is a certain number of times in which you have to press the valet button. Like a secret code.
Try on your kick panel, or below your driver's dash for the button.
Just unplug the alarm's harness.
Old Mar 22, 2004 | 05:26 PM
toy283's Avatar
You could always do what we did in the shop. We would specifically tell an owner to disable any alarms before any work. We'd still have a few that would go of. You know how loud an alarm is in a confined space? A pair of wire clippers took care of it every time
Old Mar 22, 2004 | 05:29 PM
Bob_98SR5's Avatar
PBR:
if you have the stock toyota alarm like the rs3000, just pull the harness out of the brain unit: http://www.4runners.org/articles/rs3000
i spilled some water on mine which caused it to blare without stopping. i pulled the harness and all was ok. i could not open the doors w/ the remote and had to use the key. big deal.
did you spill water on yours too?
bob
Old Mar 22, 2004 | 08:32 PM
That may silence the alarm, but the vehicle still won't start!
Bourbonblues
Dec 15, 2017 05:43 PM
runnermedic
13
Sep 21, 2015 05:20 PM
jacked_72
Sep 14, 2015 03:31 PM
carid
Vendor Advertising
Sep 10, 2015 06:11 AM
