Can you run 2 different gear ratios with ADD??
Old 12-03-2008, 07:37 PM
wmflyfisher's Avatar
My question isn't as dumb as it sounds I promise! I'm currently looking for a 4.30 E-Locker diff for the front and back. If this is my only ride, can I go with installing just the back if I don't have enough time to install both. Basically could I run the 4.30 rear with my 4.10 front as long as I don't engage the 4wd?? Wasn't sure because the front axles always turn with the ADD.
Old 12-03-2008, 07:38 PM
drguitarum2005's Avatar
Location: Houston (home), Atlanta (school), Cincinnati (work)
im curious about this too. i know part of the front diff spins because the front CVs do but I know the front DS doesn't spin so I don't know where the "disconnect" falls
Old 12-03-2008, 07:43 PM
Yeah, just not sure if I would have enough down time to replace both before I need to get back on the road. I think it can be done...
Old 12-03-2008, 07:53 PM
914runner's Avatar
I believe you can do this, as long as you don't shift into 4WD.
I have actually ran a 4.30 rear diff with 4.10 front diff offroad (in dirt, big no-no on pavement). I don't reccomend doing it, but I blew up my rear diff and only had a 4.30 to replace it with. I also have manual hubs on the rig I did this in and they were unlocked on the pavement.
I'm 99.9% sure that the front driveshaft spins independently of the rear when the transfer case is in 2WD.
Disclaimer: This is just my $.02, it's not my fault if I'm wrong and you grenade something.
jason191918's Avatar
The ADD disconnects the front left axle. When in 2hi, the Tcase is disconnected, and so is the front left axle. If you leave it in 2hi you should be fine. I would recommend removing the front DS, then damage is impossible.
Old 12-03-2008, 08:13 PM
X2 on the removing front driveshaft...its so simple.
very interesting about the front left axle...might i ask how you found that out and what purpose that serves? just curious
Old 12-03-2008, 08:22 PM
94Runner4x4's Avatar
To my understanding you can, but x3 on the front driveshaft.
Old 12-03-2008, 08:34 PM
VSU_4runnin's Avatar
wow i never thought about it that way...
Old 12-04-2008, 02:15 AM
crolison's Avatar
yeah you can, like above just take out the dshaft to be safe. I have run for 3 weeks with a 4.88 front diff with no fluid in it with my rear being 4.56
Old 12-04-2008, 03:28 AM
Maj
Maj's Avatar
As long as your t-case is a true, part-time 4WD type, you won't have any problems.
Old 12-04-2008, 05:30 AM
It should be right?? Thanks guys.
Old 12-04-2008, 06:13 AM
Ian Rogers's Avatar
just put 10% smaller tires on the front
Old 12-04-2008, 06:19 AM
Here is how I found out.
http://www.ncttora.com/fsm/1993/susp...26addcontr.pdf
I like the 10% smaller tire idea.
Old 12-04-2008, 06:29 AM
I just realized I was looking at the 1993 fsm, but the 2001 diff looks the same except it is the front right axle.
Old 12-04-2008, 06:53 AM
Maj
Maj's Avatar
I'm not familiar with Taco t-cases but if you have a mode that the factory sez allows operation of 4WD on hard, dry pavement then it is not a part-time unit.
Old 12-04-2008, 07:00 AM
If you put the tcase in neutral does it matter? Or is this not an option w/ the newer ones?
Old 12-04-2008, 12:17 PM
Sorry, I'm referring to my new rig. 02 Runner
Old 12-04-2008, 12:23 PM
eric-the-red's Avatar
If you put the tcase in neutral you won't go anywhere, it's the same as having a gearbox in neutral.
And wmflyfisher I ran my 2001 with the new 4.30 e-locked axle in the rear and my old front diff for 3 weeks with no problems. I didn't remove the driveshaft. I did pull the 4WD fuse though, just in case I accidently hit the button.
Old 12-04-2008, 12:26 PM
misterzee's Avatar
didn't I hear you say you wanted to install an elocker in both ends?
There's no Totyota Elocker for the front IFS diff....
Old 12-04-2008, 12:31 PM
My mistake. You are correct. 4.30 front and back. E for the back.
Quick Reply: Can you run 2 different gear ratios with ADD??
