Can I use addcos + lift + discos??
Old Feb 20, 2003 | 10:08 PM
Los Gatos?'s Avatar
I've been doing my studying, I've decided that swaybars + discos + lift is phase 2 of my super 4Runner plan (brakes are phase 1 I've decided on stock rotors (I could really use new ones) performance friction (TRD style) pads and SS brake lines, as well as a manual hub swap)
Anyway, my plans for lift are 2" Downey HD coils in the rear, and a cranked stock front T-bar. I also plan on a 1.5" body lift (1 " wasn't enough, 2" was too much ), but that comes later...anyway, I want to know if I can use addco f&r swaybars with disconnects with the 2" of lift? I know it's possible to, but do I need to get custom length swaybar-shizzles (forgot what they were called) or discos or whatever???
Old Feb 21, 2003 | 04:45 AM
jalaber's Avatar
Yes you can do that. Just get longer end-links (discos). Also note that when the rear bar is disconnected on a 3rd gen it will bang around and get hung up in the driver side gas tank skid plate. So you may not want discos on that end and if you wheel often may not even want a rear addco bar at all.
Old Feb 21, 2003 | 07:54 AM
Los Gatos?'s Avatar
I have a 2nd gen...does that make a difference?
Dparr2ndgen
Sep 8, 2015 01:06 PM
justdifferentials
Sep 5, 2015 06:52 PM
joeynational
Sep 5, 2015 01:54 PM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
