Can Coil Springs Be Cut To Shorten?
Old Apr 11, 2006 | 06:28 AM
Gerdo's Avatar
I want the carrying capaity of a OME 891 but I only want about 2" of lift. I want to use Tundra springs up front w/o any spacers and 891s in back but I'm afraid that the back will be way too high for the front. I would like the back about 1" higher than the front. Can I cut coil springs to shorten them? I know that anything that causes heat would not be good, but what about a cold saw?
Old Apr 11, 2006 | 06:39 AM
MTL_4runner's Avatar
You might want to read this first:
http://www.off-road.com/dirtbike/tech/2002spring/
....and to make things more complicated, the OME 890s and 891s are progressive.
Old Apr 11, 2006 | 06:48 AM
ebelen1's Avatar
Instead of cutting the spring, why not just go w/ the shorter OME springs. IIRC, they're the 906's? Anyway, search and you'll find the answer if this is another path for you?
Old Apr 11, 2006 | 07:16 AM
jacksonpt's Avatar
Senior Member
have you considered airbags? You could run the softer OME springs in the back and use the airbags to control your ride height, especially when loaded down.
Old Apr 11, 2006 | 07:36 AM
Gerdo's Avatar
MTL 4Runner
I like the look of your setup, 881/890. Thanks for the pictures you sent me. Do you have any spacers up front or is it just the spring?
Old Apr 11, 2006 | 08:26 AM
MTL 4Runner
No spacers (or trim packers) up front at all and my CV boots don't touch one another. I was debating on doing a diff drop just for insurance against wear (or if I wanted to put spacers later), but I am Ok for right now. If you do put ANY spacers in I would definately suggest a diff drop.
Here's a shot of my truck on level ground:
It also takes a little while for the springs to break in so don't rush out and get it aligned the same day or you'll probably have to do it again when they settle. Give them at least a solid week of driving (unless your steering is really off, ie it pulls to one side, bad vibrations, etc), but also don't go too long or you will probably have irregular wear on your tires.
Old Apr 11, 2006 | 11:53 AM
JimmyK's Avatar
I have heard scary stories about cutting springs. Since they are progressive and made to carry a certain type of weight if yoo cut them all their characteristics are off. It can create a lot of highway bounce and stability issues, or so the performance shop told me.
Old Apr 11, 2006 | 12:43 PM
Gerdo's Avatar
Cutting them is out of the question. Thanks for the info.
Old Apr 11, 2006 | 03:36 PM
I debated it myself and decided it was a bad idea.
sandyota
Feb 4, 2021 11:16 AM
Numberonedad6
Jul 30, 2015 07:10 PM
terminator
Jul 27, 2015 07:13 PM
Massmayhem247
Jul 24, 2015 12:07 PM
Nickdigg
Jul 7, 2015 06:04 AM
