A/C Problem
Old May 14, 2009 | 11:09 AM
hotlavaaaa's Avatar
A/C Problem
For the past year or so I've noticed that the effectiveness of my A/C has been declining. The temp of the air coming from the vents is inconsistent. Looking through the site glass I see foam sometimes and I can't tell for sure, but at times it might be running dry so I know that I've lost refrigerant. Can anyone tell me if there are common points in the system for leaks to occur? How much will I be looking at to recharge the system if it has to be evacuated? Thanks.
Old May 14, 2009 | 04:21 PM
SoCalPaul's Avatar
You most likely have a leak. I'd try the canned refrigerant first, maybe get one with dye to detect leaks. Leaks occur at connectors & valves or you could have a leak in the condenser that is in front of the radiator. You may see a small oily residue in the area.
Old May 14, 2009 | 05:49 PM
BajaRunner's Avatar
Hmm, so the 3rd gens use R134-A refrigerant?
Old May 14, 2009 | 06:59 PM
hotlavaaaa's Avatar
Yeah.
MO transplant
Apr 23, 2023 11:58 AM
stock87yota
Jul 31, 2015 10:08 AM
jackiebrownia
Jul 20, 2015 09:02 AM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
bryan34w
Jul 6, 2015 05:53 PM
