BUMP Steer???? Can anyone help
Old Jan 25, 2004 | 02:55 PM
JK 4runner's Avatar
Angry BUMP Steer???? Can anyone help
A few months ago I installed a 3 inch revtek suspension lift kit in my 97 4runner however recently my steering has gone haywire on me. Whenever I hit a bump under one of my front wheels the car is pulled in that direction and the steering wheel turns that way too. This is just with street driving. And on the highway whenever I hit a bump the car seems to float to one side or the other. two tech shops said it was my tie rod and a toyota dealer said it was my power steering rack, both of which are expensive replacements. Has anyone heard of this problem and if so, how was it corrected?
Old Jan 26, 2004 | 11:53 AM
tom_993's Avatar
You know what toe is, in regards to alignments, right? Bump steer is defined as change in toe as the suspension goes through normal up and down motions.
Let’s see if I can explain this better. Say you had zero toe and you’re driving straight. Both tires would point straight ahead, right? If one wheel went over a bump or into a hole, it should stay pointing straight ahead. If the up or down motion causes the wheel to point left or right, that’s bump steer. Note that the steering wheel will remain pointing straight ahead. The left/right of the wheels occurs only in the suspension.
A common cause of bump steer is raising or lowering the suspension. The tie rods and lower control arms must maintain proper alignment with each other to maintain zero bump steer.
Now that you understand the definition of bump steer, you can determine if this is the cause of your problems.
Here are a couple of references:
http://www.longacreracing.com/articles/art.asp?ARTID=13
http://www.derpca.com/Porscheforme/911Tech6-01.htm
http://www.bakerprecision.com/longacr17a.htm
Tom
Old Jan 26, 2004 | 06:56 PM
JK 4runner's Avatar
Thanks for your help but do you think a 3 inch suspension lift would do that??
Old Jan 26, 2004 | 09:50 PM
willymoe's Avatar
JK,
A 3" inch lift should not cause bump steer. Check for wear on the inner tie rod end or movement in the rack isolator bushings. It sounds like there is enough movement that the alignment is shifting. If these parts are worn you can get aftermarket replacements. The rack bushings (2) are being produced by Energy Suspension.
Jason
Kylenicoll33
Sep 17, 2015 08:40 AM
Jason4X4
Sep 17, 2015 08:02 AM
Papadeath
Sep 14, 2015 10:26 PM
89hilux1
Sep 14, 2015 06:13 PM
128keaton
Sep 3, 2015 05:09 PM
