Bud Built belly skid plate & gas tank skid??
Old Mar 9, 2008 | 10:59 AM
ninjarunner's Avatar
call CBI off road, my runner is there right now getting bumpers done, he could make a skid for you while he was at it.
Old Mar 9, 2008 | 09:03 PM
Matt16's Avatar
Post another pic please
Can you post another picture of this setup, I lost some tank capacity recently and I want to prevent this in the future. I have a second gen and thought about welding extra plates on to the skid plate (while its off the truck).
Originally Posted by Vermejo
Take that tank skid off and pound the dents out with a hammer. While it's off get angle welded to the bottom and call it a day.
Old Mar 10, 2008 | 07:28 AM
Vermejo's Avatar
My truck is in the shop all week, I'll post some pic's when I get a chance. Search here, TTORA and Google and you will find some write-ups on fabbing the stock skid.
Too much tweaking on the skid pan combined with added material on the bracket makes for problems. Looking at the contact spots shows the areas that need to be contoured.
Old Mar 22, 2008 | 08:30 AM
wormhole's Avatar
Got the belly skid on today (easy install) and I have one bolt leftover since I couldn't get any of the tools I have under the cat to tighten the nut .
Old Mar 22, 2008 | 10:07 AM
  #25
Vermejo's Avatar
Put the washer and nut on top of the cross member hole. Push the bolt through the washer applying pressure to both nut and bolt. Carefully thread the bolt with your fingers till it catches. Push the bolt up and get an open-ended wrench in there. Getting the nut snug will take a little time as the wrench throw is short. Try to get the bolt in there as the belly skid flexes and moves with big hits. It doesn’t really flex back to shape after severe use. Every mount counts
Old Mar 22, 2008 | 10:54 AM
  #26
wormhole's Avatar
I'll put in on before my next offroading trip next week. Going to get one of those racheting (opened/closed end) wrenchs and see how that does.
Old Mar 22, 2008 | 12:20 PM
  #27
xcmountain80's Avatar
As for the spacing I removed my stock t-case brace and it was still to close. I opted for a piece of ... 1/4 steel stock on the end closest to the gas tank, and drilled 3 holes to match the pattern of the ass end of the skid.
Aaron
Old Apr 13, 2008 | 03:39 PM
  #28
wormhole's Avatar
Finally pulled the skid plate off today and no damage to the tank.
That puts my paranoidia to rest.
Old Apr 13, 2008 | 07:04 PM
  #29
toy_tek's Avatar
I pulled my gas tank skid off last week, I should post some pics because its bent up about 3 inches in the center. Lost about 3-4 gals capacity in the tank. Pumped some compressed air in the tank and Boom... everything back to normal. I tried pounding the skid back into place with a 5lb sledgehammer, no luck. I'll take it to work and let our Bobcat do the trick.
SOAZ - lets get this party started...
Old Apr 13, 2008 | 08:49 PM
  #30
SOAZtim's Avatar
Lets do it!
I can draw it up in the plasma program. Want to meet sometime after work this week and I can start measuring.
Old Apr 14, 2008 | 04:02 AM
  #31
I have nothing to report other than my BBS got a new paint job. I call it Spotted Ray.
Aaron
BeMiceElf
Oct 10, 2015 09:40 PM
skoti89
Sep 11, 2015 07:46 AM
pyramid
Jul 30, 2015 10:05 AM
pyramid
Jul 29, 2015 06:53 AM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
