Brake Pad FSM?
Old Jul 17, 2006 | 09:06 AM
04 Rocko Taco's Avatar
Question Brake Pad FSM?
I need pretty quick help on front brake pads on an 04 Tacoma. From what I've seen they are pretty easy. Don't even have to remove the calipers, unless you are turning the rotor.
From what I have seen, pull out retaining clips, then retaining pins, pads slide out of the top of the rotor, and then compress the pistons, and then slide everything back in in the opposite order, right?
If anyone has the FSM or any other helpful suggestions on this, I would be GREATLY appreciative. I am leaving for a long road trip, need to get these changed, tonite, if possible. Thanks guys!!!
Old Jul 17, 2006 | 11:10 AM
MTL_4runner's Avatar
Yep, you can do them without removing the calipers if you are going to do anything with the rotors.
http://www.deserted1.com/FSM/Repair_...4wdpr/repl.pdf
Old Jul 17, 2006 | 12:03 PM
midiwall's Avatar
Jamie's typing too fast...
Originally Posted by MTL_4runner
Yep, you can do them without removing the calipers if you are NOT going to do anything with the rotors.
Old Jul 17, 2006 | 12:33 PM
Thanks a lot Jamie. Question though. Where do you guys get access to these FSM's? somebody work for Toyota or is there somewhere I can get it too?? Thanks!!
Old Jul 17, 2006 | 04:42 PM
Hehehe.....I blame it on the heat!
trailgoat
Aug 13, 2015 05:54 PM
snap-on
Aug 10, 2015 05:19 PM
ty1er
Aug 1, 2015 11:53 PM
harrisdawg
Jul 26, 2015 09:42 AM
colasurdo
Jul 19, 2015 10:36 AM
