Body lift
Old Feb 3, 2003 | 07:31 PM
fooddude's Avatar
Body lift
i was wondering what size of tires i could get if i got a 3 inch body lift on my 94 4Runner.
Old Feb 3, 2003 | 07:34 PM
L33T35T 4Runner's Avatar
big
Old Feb 3, 2003 | 08:46 PM
Churnd's Avatar
Originally posted by L33T35T 4Runner
big
"big" meaning 33x12.5's.
Old Feb 3, 2003 | 11:40 PM
DeathCougar's Avatar
Proper Body Lift
Along these same lines, Im looming to put a 2" Body lift on my 90 Runner 4dr. What companies make the best lift, and aside from the spacers and bolts, what other parts will I need to make everything function smooth (so far I know about the gas tank spacer, steering spacer, rad. drop brackets, and shifter extension) I dont need to worry about the bumpers, my friend Jeff is going to weld me custom bumpers.
Also, is there a way to lift the gas tank up 2", so the driveline will be farther from it? I figure with 2" more clearance to the body, i can lift the gas tank up, which will give me more ground clearance too. Thanks
Old Feb 4, 2003 | 02:46 AM
UKMyers's Avatar
Think you could fit 33's with the Downey set up and a 2" body lift. Things get much more complicated going from 2inches to 3. Death Cougar I used to come fly my ultralight to the airshow there in Arlington every year for a quite a while.
Old Feb 4, 2003 | 06:08 AM
Corey's Avatar
Co-Founder/Administrator
Roger Brown (4Crawler Off Road) makes the best body lifts period.
Many run his kits, and he is on all the forums, and all are happy with the kits.
Look in our Vendor Links section here for the link to his site for more info.
2" body lift and you are looking at extending your shifters and radiator, and front bumper brackets.
1" lift none of that required.
Old Feb 4, 2003 | 08:50 AM
Robinhood150's Avatar
Plus, with a 1.5 inch rear coils, a torsion bar crank, and slight pounding/cutting of the wheel well, you can still fit 33s.
Steve
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
upongame619
Aug 1, 2015 12:12 AM
Cabell
Jul 24, 2015 12:14 PM
Backcountry411
Jul 24, 2015 08:06 AM
