Blinker issues
Old Jul 30, 2004 | 06:13 AM
Blinker issues
I am having the strangest problems lately with my 87' ext cab 4x4 22r truck. The blinkers all work fine but the guage arrows dont light up when the blinkers are on and the backlighting for the guages for when it's dark does not work either. I have looked all around this thing and found nothing. Any suggestions?
Old Jul 30, 2004 | 07:14 AM
mt_goat's Avatar
Sounds like a wire is shorting out. I'd stop using your blinker until you find the short as it could be a fire hazard. Time to buy a multi-meter and learn to use it or take it to someone who can trace it down for you. I think you want a multi-meter that will check continuity, but I'm still learning about mine. The insulation can wear off wires after 15 years of bumping around.
Old Jul 30, 2004 | 12:27 PM
Sparman's Avatar
Have you checked your fuses. If I'm not wrong, the dash indicater lamps and the illumination are on the same fuse.
Old Jul 30, 2004 | 01:30 PM
Yeah, the fuses are all good. I have a DMM and I hope I know how to use it. I went through the ASE cert classes I would think that a shorting wire would pop a fuse right? Well, I checked all the wires anyways and nothing is grounding out anywhere near the dash area. I will check out the trailer lighting setup tomorrow as I am thinking that is a possibility. Any other suggestions?PS I have always owned the 22re and I must say that I am majorly impressed with the smoothness of the carb version. Much better power in my opinion even though numerically higher hp resides with the 22re. Todd
bigjstang
Jun 2, 2025 03:56 PM
nvdesertrunner
May 11, 2020 08:18 PM
ghostmoney
Jan 28, 2018 11:42 AM
crammit442
7
Nov 29, 2017 12:30 PM
rjtrials
Aug 6, 2015 07:25 PM
