Black smoke on start up
Old Sep 29, 2005 | 03:06 PM
JEDI87's Avatar
I am having an issue,not big,truck still runs great but when I first start the 4runner in the morning and rev it I get some black smoke.It wasn't there before the engine was built.I do have a bigger cam so that's where I'm guessing it's coming from.It goes away after it warms up.It idles and runs great but the little blacks dots of moisture on the driveway are getting annoying.Could it be the cold start injector or just some computer tuning?
Old Sep 29, 2005 | 03:34 PM
Fahrenheit 451's Avatar
Sounds more like the TPS. Check it soon and make sure it is right. The two different shops that were supposed to check mine after installing an LC EFI Pro motor screwed the pooch and it wound up costing me a bunch of $$$ and a new headgasket. Plus, if it is far enough out, you will be washing down the cylinder walls and getting gas in the oil. Just not the sort of things you want to be doing with a new motor.
The bigger cam would tend to make the engine run lean and not rich I believe. Other possibilities would be the cold start injector which may be leaking fuel into the intake when the engine is shut down so it has excess fuel to burn on start up.
Old Feb 3, 2006 | 06:51 PM
JEDI87's Avatar
I had toyota check it and it was ok.
Old May 1, 2007 | 08:10 PM
JEDI87's Avatar
I'm thinking now that the old (stock) injectors are leaking when it's shut off and hen it's fired again, burns it all up, sound right?
steve miller
Oct 10, 2015 01:40 AM
raiderhawks00
Jul 8, 2015 06:23 PM
Nickdigg
Jul 7, 2015 06:04 AM
mickyd9990
Jul 6, 2015 09:01 AM
