Bilstein HD vs Bilstein 5100
Old May 1, 2005 | 04:20 PM
CoedNaked's Avatar
Bilstein HD vs Bilstein 5100, Downey Leaf Springs & Torsion bars
It says on the Bilstein website that their 5100's are designed for lift kits and the like where as the regular HD's are designed to compliment the OEM mounting configuration and ride height. It mentions specifically on the Bilstein website something about a 3-4" lift using their 5100's. What if you had leaf springs (in the rear obviously) that gave a 2" lift, and you had downey 26 MM torsion bars in the front (which I'm thinking about) and cranked them a little bit to match the 2" lift in the rear? Would you go with 5100's or the regular HD's in this case?
Also, if anyone has the Downey leaf springs in the rear with the 2" lift, and the ones with the 3" lift I'd be interested in seeing pics on your 89-95 Toyota 4x4 as well I'd be interesting in hearing reviews on the 26 MM torsion bars if you have them as well.
Old May 19, 2005 | 12:10 AM
TheLaw's Avatar
I have the same question, but for the 4runner, with 2-3" of lift. Should I use the 5100s or stick with the HDs?
Old Jun 9, 2005 | 04:54 PM
fatdudesurfin's Avatar
i'd like to know too, whether the 5100's will fit with only a minor front end lift (1.5" bj spacer in my case)
Old Aug 24, 2005 | 05:56 PM
anyone have some help for this one? im still stuck deciding on shocks. if those bils will work for me ill go with them
Old Aug 24, 2005 | 06:00 PM
Silver_Truck's Avatar
yes get the 5100s and if you've got cash and want the bling go with 5150s in the rear. and yes for Fatdude get the 5100s, 3-4" lift shocks work good with BJ spacers. I've got 2" of lift with my Chevies, not the same springs but same amount of lift, I had 3" so you could see both heights if you want.
ZGjethro
Jun 7, 2017 11:04 PM
Scottcrb
Mar 3, 2016 11:57 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
toyotasaurus
Sep 24, 2015 03:30 PM
JookUpVandetti
Sep 17, 2015 09:25 PM
