Bigger tires impact ABS?
Old Jul 8, 2003 | 09:19 AM
sdrunner's Avatar
Do larger tires impact the ABS speed sensors? I switched tires from 225/75/R15 to 31x10.5 R15 on my 1997. I recently needed to make an emergency stop. Instead of the ABS kicking in, the wheels slid on the pavement.
Old Jul 8, 2003 | 09:41 AM
jacksonpt's Avatar
Senior Member
I went from 29s to 32s and didn't notice anything... my ABS still kicks in like it always has.
Old Jul 8, 2003 | 11:54 AM
Does your ABS dash light come on for a few seconds then go out after you turn ignition on? Might be your ABS system is not working.
Old Jul 8, 2003 | 11:55 AM
Gbost's Avatar
I went from 31's to 33's and have had no problems.
Greg
Old Jul 12, 2003 | 10:31 PM
colt ar's Avatar
my buddy was told from the dealer not to change wheel size or tire size because it would effect the abs,this was on a 2001 tacoma.I also heard guys were just disconnecting the abs when going with bigger wheel packages
Old Jul 13, 2003 | 12:01 AM
Jeff the marmot's Avatar
Yes, larger than stock tires will affect ABS because the tire will decelerate at a different rate since it has more rotating inertia. So your ABS will be less sensitive to notice the onset of locking up a wheel(s), although ABS will still mostly work as long as you're only increasing a few inches in tire size.
Sep 4, 2015 09:27 AM
94ofCanada
Aug 14, 2015 06:37 AM
nickbeauregard
12
Aug 7, 2015 06:04 AM
ty1er
Aug 1, 2015 11:53 PM
Michael oaks
Jul 27, 2015 11:47 AM
