Bigger Tires?
Old Dec 15, 2004 | 10:40 AM
Bigger Tires?
I lifted the rear end of my 4runner with coils 1.5" and i cranked my t-bars in the front to even the truck up. I have 31's right now and i'de like to bump up a bit. I don't want to lift the truck anymore however. I want to put a set of bfg at's 32x11.50x15.. Anyone know if this can be done without the tires rubbing
thanks chris
Old Dec 15, 2004 | 10:56 AM
lee's Avatar
lee
might want to mention year.
Old Dec 15, 2004 | 11:10 AM
firemedic's Avatar
You're right, but it's gotta be 2nd gen (90-95) w/coil spring rear and torsion bar front.
I'm planning on going to 32x11.5x15, with the same setup, downey 1.5" HD springs should arrive today, then mess with t-bar, then when time/money allows 32's. From what I've been reading I "should" be OK, w/out rubbing, but open to any more advice/opinions.
Old Dec 15, 2004 | 12:41 PM
its a 93 it looks like theres alot of room in the wheel wells
Old Dec 15, 2004 | 12:45 PM
NRM's Avatar
NRM
krazxyglue, i've got a '95 runner thats not lifted at all and i just put on 32x11.5x15 and they barely rub at all. only with the wheel just about locked out and backing up does it rub at all. you should be fine with the 1.5 in the back and the t-bars cranked.
Old Dec 15, 2004 | 12:47 PM
914runner's Avatar
thanks chris
Do you ahve stock wheels? I have 32x11.50's on right now with stock wheels. I have running boards (not OEM Toyota ones) and had to modify them so they wouldnt rub, but from the looks of the OEM Toyota running boards, they shouldnt rub there. Mine rub only on the fender liner that covers the gap between the body and the frame and keeps dirt out of the engine bay, so nowhere big.
Old Dec 15, 2004 | 07:08 PM
BeaterToyota's Avatar
You'll be good. I ran 32x10.50 Super Swampers on my junk with no lift at all. They're skinnier than what you're looking at, but they're also a bit taller. You won't have problems.
Old Dec 16, 2004 | 05:53 AM
thanks guys i appreciate the input
Sep 4, 2015 09:27 AM
Dakotaneu
Aug 15, 2015 07:24 AM
94ofCanada
Aug 14, 2015 06:37 AM
nickbeauregard
12
Aug 7, 2015 06:04 AM
Michael oaks
Jul 27, 2015 11:47 AM
