belt slipping?
belt slipping?
97 v6 manual tran, 126k
I have issue with high rph acceleration, anyhting above 3500 feels feels like a belt or something is slipping, especially in higher gears..... the engine runs smoothy and revs up, but I dont accelerate unless I let off and accelerate more smoothly.
I wanted to see what you guys thought it was sounds like
https://www.yotatech.com/forums/f2/timing-belt-seals-77187/ might work, but I wanted to see if it was timing belt or a compression issue
thx in advance
thx in advance
Maybe the MAF sensor... do you have a aftermarket filter in there...The oil gets onto the MAF (Mass air flow sensor) and does what your saying screws with the horse power as to where your not going fast at all or atleast not fast enough...
https://www.yotatech.com/forums/showthread.php?t=77187 might work, but I wanted to see if it was timing belt or a compression issue
thx in advance
thx in advance
Originally Posted by MTL_4runner
If the engine is accelerating normally under load but it still feels like you are slipping it probably is your clutch.
A MAF problem or compression issue wouldn't cause this; if it was a timing belt slipping, you wouldn't be running at all.
So just to eliminate possiblities, given I clean my intake out how do you reset the MAF? just take the fuse out? I dont have an aftermarket filter...but I did the airbox mod or whatever taking the elbow out. This problem is been coming and going
thanks guys
try this on a flat road... at those rpm's depress the clutch w/o lifting your R foot, release the clutch, it should jump a little as the clutch grabs. if it doesn't, this is likey the source of the problem.
could try bleeding it or adjusting too.
Anyway... Either pull the negative battery cable for 30 seconds, or pull the "EFI" fuse which is in the fuse box under the hood (driver's side, on the fender, just behind the battery). The EFI fuse should work, and won't have to reset your clock or lose your radio presets.
Originally Posted by midiwall
Just for the semantics, you don't "reset the MAF", you "reset the ECU".
Thanks again for the help guys.
clutch
Put foot on brake and put truck in gear and let out the clutch.Dont give it any gas just let the clutch out in gear.If it dosent go dead right off the bat and chugs on for a second or two more than likely you need a new clutch.If you are going up a hill and step on the gas and the rpms go up but you dont speed up.You need a new clutch!
primordialbeast117
Dec 19, 2015 12:23 PM
