Battery starter guestion
Old Feb 28, 2003 | 09:25 AM
trd90toyota's Avatar
Question Battery starter guestion
Could a battery with the really high CCA's burn out a starter?
Old Feb 28, 2003 | 09:42 AM
rimpainter.com's Avatar
CCA: Cold cranking amps. Maximum number of amps a battery can supply for 30 seconds at a temperature of 0 degrees F, before dropping to 7.2 volts.
I would say no. The voltage would not change with more CCA's. If you cranked it over for a long time, then yes. But any battery could do that.
Old Feb 28, 2003 | 09:52 AM
bldavis11's Avatar
No, the voltage won't change relative to the max current. Apply Ohm's law V=IR. Voltage will always hover around 12.0 V. Thus the only thing you can vary is resistance which is in fact how the higher CCA voltage sources work.
More so than that, think of it this way. The total resistance of the system is what matters. The resistance of the wires from the battery to the starter is more or less constant for all the 4R's, as well as the induced resistance for the starter. Once again voltage is fixed, the resistance is fixed, the internal resisance of the battery is more or less neglidgable in nearly all cases (we'd be talking about 4th or 5th decimal place), thus output current must also be fairly constant from 4R to 4R.
We could attempt to test the idea by measuring current flowing from the battery during cranking for a couple of different rigs. I propose that they will be more or less equivilant.
You're fine with the new battery.
-Davis
Old Feb 28, 2003 | 10:02 AM
bldavis11:
Is your real name Will Hunting by any chance?
Old Feb 28, 2003 | 02:35 PM
bldavis11's Avatar
i wish! I had a long writeup about the fuel atomizer discussion that was going on back in January, but after I wrote it, I realized that wasn't a registered member yet. Alas.
I'm a medical student with a masters in nuclear engineering and a b.s. in biological engineering. you get a pretty heavy dose of the physics that way.
-davis
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
Bourbonblues
Dec 15, 2017 05:43 PM
Naween Zohab
Nov 10, 2015 03:56 PM
JPV
Sep 28, 2015 03:15 PM
toyotasaurus
Sep 24, 2015 03:30 PM
