From bad to worse...
Old Aug 9, 2005 | 07:16 AM
Renegades's Avatar
Hey guys,
last week i was in a wreck and messed up the front end on my 97 runner. The estimated cost of repair will be around $1600, im supposed to get a 2nd quote today...i'll be sure to post some pictures. Anyways, I wake up this morning, go out to my car, get ready to drive away, and my back and butt start feeling wet. I look up and my sunroof is open. There was a big rain storm last night and of all the nights i accidently left my roof open, it decided to rain. Well thats not all, I dry everything off, get ready to leave and it wont even start...right about now i've just about had it.
I've had the starting issue before, but not this bad. Usualy every couple weeks when i turn over the engine it'll just click, so i do it again about 4 times and it finally starts up (once the engine is warm it wont do it, only if the engine is cold, and only every once in a while). Well today, of all days, its not working Period. It'll just click every time, i got out, checked the battery terminals and there was green acid build up, i used soda and a skrewdriver and got it all cleaned off. Once i re-attached the terminals, it still did the same old clicking. Plus my quote appointment is at 2 today, i better get this thing fixed soon.
If you guys have any suggestions or answers to my problem it'd be great, Thanks in advance for the help.
-Micah
Old Aug 9, 2005 | 07:50 AM
One More Time's Avatar
Have you noticed if it has always had problem starting after it rains? Have you checked your spark pugs and wires?
Old Aug 9, 2005 | 08:04 AM
SloPoke's Avatar
Well, sounds like worn starter contacts to me.
Roger Brown provides great detailed info on that here http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Probably can't fix it by you appt. time but you should be able to tap or bang on the starter to get it working. Then do the fix this PM after getting contacts at a local Stealer. If you can at all wait a couple days to perform the repair, get em from Roger through the link.
Old Aug 9, 2005 | 08:06 AM
rimpainter.com's Avatar
Just turn the key from ON --> START, ON --> START rapidly and it will eventually catch. But yeah, it's gotta be the contacts. Took me an hour to replace mine. Easy and cheap.
Old Aug 9, 2005 | 07:06 PM
Renegades's Avatar
Alright thanks for the help guys,
I took it by the shop today and dropped it off, they're gonna look at it tommorrow. Once i get that fixed i'll get my body repaired and then get the OME lift installed along with the 285s, then i'll be set...hopefully.
Thanks again,
Micah
ghostmoney
Jan 28, 2018 11:42 AM
Blamalam
Aug 16, 2015 12:29 PM
corey519
Aug 12, 2015 11:12 AM
nonstop
7
Aug 11, 2015 09:26 AM
keithporter83
Jul 18, 2015 12:37 PM
