Is it bad to....
Old Dec 23, 2004 | 04:31 PM
brendonv's Avatar
Is it bad to....
Is it bad to put your truck in 4low without locking the hubs (manual), and just use it as 2wd low?
Old Dec 23, 2004 | 04:34 PM
jimbo74's Avatar
its perfectly fine, just watch your speed as its easier to break loose the tires in 2lo then 4lo, and the low range system does not like excessive speed
Old Dec 23, 2004 | 05:08 PM
EWAYota's Avatar
when would you use 2 Low?
Old Dec 23, 2004 | 05:20 PM
arjan's Avatar
I used it for backing up the trailer around corners and in tight spots. It goes slow enough so you don't have to ride the clutch.
Old Dec 23, 2004 | 05:59 PM
brendonv's Avatar
same as arjan, helps alot manuevering in a yard with a heavy load of wood or trailor...
Old Dec 23, 2004 | 06:14 PM
jimbo74's Avatar
also a lot of people use it on boat ramps when entering or exititng the trailer into the water
Old Dec 24, 2004 | 04:33 AM
Ilovemountains's Avatar
I do this often.
My yota is a 3.slooow automatic, I use 2 low a lot, when I have a load in the yard, or am using my truck to pull something heavy, I moved some LAAARRRGGGE stones that the excavators pulled out of my property when they installed my new septic system, and they are about the size of a Yugo! I also use 2Low when I am wheeling quite often.. There are a lot of trails that I run that you don’t need to lock the hubs if it hasn’t rained or if there is no snow, my Revos have helped out a lot with this! I put the trans in drive, and let it shift into 2nd gear, I can then basically crawl my way through just about anything in 2 Low, and it doesn’t heat up the trans or strain the engine at low RPMs. This is nice since most of the local trails are about 25 miles away and if you don’t need your hubs locked, why lock them for the road!
Old Dec 24, 2004 | 11:10 AM
Ironmike4x4's Avatar
Yeah it should be fine, just keep it in the low gear range though the same as 4lo.
Old Dec 24, 2004 | 11:46 AM
kyle_22r's Avatar
that's what i use it for. makes it easier on the clutch and puts less shock on the trailer hitch than you would by putting it in 1st and slamming on the gas
Old Dec 24, 2004 | 12:01 PM
Beach-Rat's Avatar
For backing trailers with thw 4runner it's good.. for backing a big trailer with a high torque diesel & leaf springs it's GREAT...
Old Dec 24, 2004 | 12:07 PM
Bigblock's Avatar
stay out of O/D in low .
Old Dec 24, 2004 | 02:39 PM
birfieldwheer's Avatar
I like using 2low for stop and go traffic. It gives my left foot a break as I dont really touch anything, but a little brake.
Just leave it in gear and crawl baby!
ghostmoney
Jan 28, 2018 11:42 AM
Blamalam
Aug 16, 2015 12:29 PM
corey519
Aug 12, 2015 11:12 AM
nonstop
7
Aug 11, 2015 09:26 AM
keithporter83
Jul 18, 2015 12:37 PM
