Back spacing on a 3rd gen
Old Sep 1, 2003 | 06:12 AM
Cmar's Avatar
Question Back spacing on a 3rd gen
This question has probably been asked before, and I have used the search function, but I'm think of getting new rims and want to be sure of the correct back spacing.
I have stock 16 x 7 Toyota rims on my 3rd gen and I love the look of the Mickey Thompson Classic II's.
So if I was getting 16 x 8 in the new rims, what backspacing should I get. The rig is stock height etc, at the moment. But I'm thinking of getting the RB 2" bodylift.
If I keep the stock height, what tire size can I go up to without rubbing (currently have 265/70's)
Sorry for all the q's but hopefully I'll get some definate answers!!
Cheers Guys
Old Sep 1, 2003 | 09:52 AM
Darren's Avatar
I had the same dilemma when getting the Classic II's. In fact, you probably came across some of my posts about this.
Basically, they come in two choices as you're probably seeing: 4 9/16" and 3 5/8". The problem with 4 9/16" back spacing is that they won't clear the brake calipers in the front. The problem with 3 5/8" is that you will have to do quite a bit of trimming and what not if you go off-road. If you don't go off-road and don't stuff your front tires, then the 3 5/8" would probably be optimal.
I didn't want to put up with the additional trimming the 3 5/8" would require so I opted for the 4 9/16". I had custom 1/4" spacers made and all is working out nicely, though they do rub more than the 7" wheels. I've got to start beating the heck out of my wheel wells now.
The tallest tire you can go without lifting would be 265/75/16.
The answer to the subject line is that the OEM 3rd Gen wheels have 4 3/8" back spacing.
Now go and order those things!
Old Sep 1, 2003 | 10:09 AM
Cmar's Avatar
Thanks Darren
Just looked through your site... wow nice rig man!
Your rig is an image I would like to see for mine, but I don't think I will be as hardcore.
My vision for my rig is the MT Classic II's with bigger tires. A 2" rb body lift, and a Surco rack. So over the next few months I'll will hopefully adding the stuff.
The 3 5/8" BS would probably suit me as I don't intend to do any major offroading and might not go as big as the 285's. So would 275/70/16's with the 2" lift suit the 3 5/8" 16 x 8 MT classics?
Old Sep 1, 2003 | 10:22 AM
Darren's Avatar
Thank you right back at ya!
275's would also be fine on the 8" wheel.
Old Sep 1, 2003 | 10:51 AM
waskillywabbit's Avatar
285s
I have a 2" RB body lift and 285/75/R16s on 16x8 rims and I rub slightly on full turn. I am going to add the SAWS up front with some OMEs in the rear and that should take care of that.
Hope this helps.
Brian
Old Sep 1, 2003 | 10:55 AM
Cmar's Avatar
What back spacing do you have Brian?
Is there much difference between 285/75's and 275/75's?
Thanks
Old Sep 1, 2003 | 10:58 AM
dunno
Thanks
Sorry, but I have no idea. They are American Eagle 16x8 rims for 4x4 SUVs. I am sure you could find them in an online catalogue. I do know that the brake calipers rubbed slightly on the front so they had to grind/polish them down just a little. Like I said, I have slight rubbing on full turn, but that is it. I did take my fender flares off though until I get up higher because there is one bolt for the flares that would be right where it is rubbing. So keep that in mind too.
Brian
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
Steezy96yota
Jul 6, 2015 10:00 AM
Suprarossa
Jul 6, 2015 05:21 AM
coryc85
Jul 6, 2015 04:07 AM
