Auto Transmission Flush question/help
Originally Posted by Lone4runner
if you bring it to a dealership like IRA they will usually take care of it for you. I worked in a dealership on the south part and usually they are pretty thorough. mostly because theres alot of dealerships around for toyota and they dont get paid as much so usually they will do a few checks to make sure everything is ok.
I'll give them a call, can't hurt.
unlesss you feel like taking a rid eto hanover IRA' s the only other one that i can safely say its ok. MCgee toyota has the most master techs in the state so technically if you are really worried about dealers I would say use them and you will not be disappointed but its a hike depending on where you are.
mcgee on the lynnway in lynn?
Ira wants $149, does not include filter kit, he wasn't sure the cost of that somewhere between $35-$50 more.
geez, these prices seems high to me!
yeah they are high 89 of that is probably just the shop rate. Other option as i said was valvoline they were quoting me only a hundred dollars before. Mcgee is in hanover on the south shore. I also wouldnt worry to much about the filter its not that important to change or maintenance at this time.
#25
I had the BG tranny flsuh done just about 3K ago and it did make a difference. Ask the shop if they have the cleaner that they should install first before they start the flush. Also BG recommends that you put in an additive after teh flush. BG stuff is only sold to shops you can not buy it at a chain store, that is just the way they work.
I would do the BG flush..........
FS[PacSouthWest]: FS: 1988 4RUNNER FRAME 4X4 IFS Located in Lancaster Ca
4x4-runner
Aug 30, 2015 08:55 AM
FS[PacSouthWest]: 1988 4runner $1500
4x4-runner
Aug 3, 2015 07:14 PM
