atf additives in power steering?
Old Feb 3, 2010 | 08:14 PM
hpctoy's Avatar
My power steering is notchy and I don't have the time or money to replace the pump right now. I drain the fluid and put in new atf and it's better for about 3000 miles or so, but then gets notchy again, especially when cold. Anybody try any aftermarket additives that might smooth things out for awhile? I assume the power steering additive is a bad all because it's designed to work with power steering fluid, not ATF. Will ATF/tranny additive help a power steering pump?
Thx
Old Feb 3, 2010 | 09:48 PM
quicksilvr's Avatar
Instead of using ATF, use straight Marvel Mystery Oil. Works like a charm. It's a mystery!
Old Feb 4, 2010 | 11:55 AM
FogRunner's Avatar
Short answer : Flush it out and fill it with Mobile One Synthetic ATF its gonna cost you a couple bucks more than dino ATF but holds up allot better.
Long Answer : There are several problems with ATF that synthetics ones handle better. Problem one is heat, ATF starts to break down around 235-240F. In power steering system such as on the 4runne there is no power steering cooler so fluid temps can very easily get in that range on a warm day of city driving.
The other issue is pressure, ATF was never intended to be subjected to the 3,000 PSI that a power steering system puts on it. Because of this pressure heat builds up easily and quickly and destroys the fluid.
Once ATF starts to slightly degrade, it looses some of its properties so it heats up easier, so it degrades quicker which means it heats up even quicker and so on.
So even if you don't have P/S problems its a wise idea to flush and fill your 4runner and Taco P/S with synthic fluid to prevent a problem from forming.
FOG
Old Feb 4, 2010 | 12:32 PM
mt_goat's Avatar
FOG
X2, I use Mobil 1 ATF and also added an extra cooler for the PS.
Zpd426
Jan 2, 2016 01:15 PM
delmert
Sep 30, 2015 04:34 PM
Up&Down
Aug 11, 2015 10:04 AM
toyoterferdayz
Diesel Swaps
Jul 27, 2015 05:25 PM
gmonnie123
Jul 26, 2015 02:44 PM
