Aquamist high-speed valve question
Old Aug 1, 2006 | 02:36 PM
mt_goat's Avatar
Where are you guys putting the high-speed valve for the WI? Should it be as close as possible to the throttle body or does it matter? Gadget's instructions just say to find a suitable location.
Old Aug 1, 2006 | 05:16 PM
midiwall's Avatar
It doesn't really matter... Some place that makes sense, and where the hoses will be exposed to minimal heat.
Are you running a URD tank? If so, then the AM pump fits right on it, and you can put the valve down there too. That'll keep it out of the heat. I have a LOT of heat under my hood and I blow that plastic line all the time.
(when did you get an AM system? hmmm... )
Old Aug 1, 2006 | 06:34 PM
mt_goat's Avatar
No URD tank, just a washer bottle. I got it when I got the SC and URD kit about 6 months ago. Here's what I got installed so far: http://community.webshots.com/photo/...42310107rvyYZM
http://community.webshots.com/photo/...42310107eFPupB
http://community.webshots.com/photo/...42310107KrwChB
http://community.webshots.com/photo/...42310107HpjsWy
Old Aug 1, 2006 | 10:01 PM
midiwall's Avatar
Looks great Dale! I'm dying to get mine installed.
Old Aug 2, 2006 | 03:30 AM
mt_goat's Avatar
Thanks, you better get going Mark
I got an answer from Gadget over on CT: http://www.customtacos.com/forum/showthread.php?t=69130
Old Aug 2, 2006 | 05:26 AM
midiwall's Avatar
(copying here for the sake of our archives)
Originally Posted by Gadget
The closer to the nozzle the better, but you have to work around a good installation location also. Behind the brake booster I would think is way to far away. I would make every effort to keep it no longer then 6".
I can see his point in that once the pump starts, you have to fill any empty space in the tube before you get mist out the nozzle, but 6"? You're in quite the hot zone at that point.
the1998sr5
15
Jul 14, 2020 08:35 PM
coleypull15
Nov 3, 2015 07:41 AM
thefishguy77
Jul 30, 2015 10:59 AM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
