Anyone up to helping?
Old Oct 30, 2005 | 06:54 PM
  #141
Localmotion's Avatar
AWESOME progress!!!! You gotta get taht best up and running! Man...that sure is a pretty engine bay...hell even the oil pan is purrdy
Old Oct 31, 2005 | 04:33 AM
  #142
FilthyRich's Avatar
hell yes. Glad to see it all come together. Better late than never
Old Oct 31, 2005 | 04:38 AM
  #143
callmej75's Avatar
thanks guys...gotta late night of hooking up everything so I hope to hear it run tonight.
Old Oct 31, 2005 | 04:41 AM
  #144
Strap22's Avatar
Sponsoring Vendor
Looks great...............
Old Oct 31, 2005 | 03:42 PM
  #145
hektikwon's Avatar
Man I sure hope that bad boy starts and runs good. Did you put the engine stiffener I send you on there?
Old Oct 31, 2005 | 07:46 PM
  #146
callmej75's Avatar
Sure did...its now yellow!
Old Oct 31, 2005 | 08:37 PM
  #147
cootees's Avatar
Did you get to fire it up today?
Old Nov 1, 2005 | 03:43 AM
  #148
callmej75's Avatar
Nah I got the upper plenum on and realized my cold start injector needed to be routed directly underneath the plenum instead of around. One of my tips on my Iridium plugs broke and it was too late to go back and get another so I got the P/S pump and alternator on with all the belts. Noticed I had a T missing from my vacuum line that connects the vacuum line off the master cylinder with another line at the passenger side. Got all the exhaust hooked up. I'm going today and get them parts I need and finish up tonight.
Old Nov 2, 2005 | 04:12 PM
  #149
callmej75's Avatar
Got it together...coolant leak on the front of the motor somewhere under the timing cover. To be continued.....
Old Nov 3, 2005 | 06:00 AM
  #150
callmej75's Avatar
Coolant leak stopped over night..cranked it over and I got a fuel leak under the plenum. Diagnose that this evening.
Old Nov 3, 2005 | 06:11 AM
  #151
Strap22's Avatar
Sponsoring Vendor
INSTALLATION OF COLD START INJECTOR
1. INSTALL COLD START INJECTOR
(a) Apply sealant to 2 or 3 threads of the bolt end.
Sealant: Part No. 08833–00070, THREE BOND 1324 or
equivalent
HINT: This adhesive will not harden while exposed to air.
It will act as a sealant or binding agent only when applied
to threads, etc., where air is cut off.
(b) Place a new gasket and install the cold start injector
with the two bolts.
Torque: 80 kg–cm (69 in–lb, 7.8 N–m)
2. INSTALL COLD START INJECTOR TUBE
Using new gaskets, connect the cold start injector tube
with the union bolts.
Torque: 180 kg–cm (13 ft–Ib, 18 N–m)
3. CONNECT COLD START INJECTOR CONNECTOR
4. CONNECT CABLE TO NEGATIVE TERMINAL OF BATTERY
5. CHECK FOR FUEL LEAKAGE
– EFI SYSTEM Fuel System (3VZ–E)
Old Nov 3, 2005 | 06:13 AM
  #152
callmej75's Avatar
good deal...
Old Nov 3, 2005 | 04:58 PM
  #153
callmej75's Avatar
Cold start injector hose busted in two places.....on order and will be here Saturday morning.
Old Nov 4, 2005 | 09:28 AM
  #154
Strap22's Avatar
Sponsoring Vendor
Located hose and it is being shipped today from Houston. You should get it in the morning.........let me know......
Old Nov 4, 2005 | 11:21 AM
  #155
callmej75's Avatar
Good deal
Old Nov 6, 2005 | 06:34 PM
  #156
callmej75's Avatar
*done*
2 cam seals and one valve pan cover seal later...its finally in the driveway!
Old Nov 6, 2005 | 07:21 PM
  #157
cootees's Avatar
Yay! Now how much paint did you scrape off of the motor during the installation?
Old Nov 6, 2005 | 07:27 PM
  #158
callmej75's Avatar
A little here and there...but the scrapes are well hidden!
Old Nov 6, 2005 | 07:50 PM
  #159
FilthyRich's Avatar
Hell YES!!!! Finally.
Glad to see it alive....when are we wheelin'??
Old Nov 6, 2005 | 07:57 PM
  #160
callmej75's Avatar
Its been a deep dark road that I prefer to never go down again...I still gotta put in the front cv's and get the recall done and the bj spacers but I should be game within a few weeks after I see how its broken in. Without Phil and his overnighting parts then she would still be sittin! Gonna check my timing tomorrow and the distributor to make sure I'm notta tooth off or anything. Still misfires at startup but it quits after about 3 minutes of warming up. All in all she still goes slow just as the day she was when I parked her!
