Anyone have a clue what would cause this?
Old Feb 2, 2005 | 09:30 PM
1987 street toy's Avatar
Question Anyone have a clue what would cause this?
my brother has a 83 (i think) gmc s15 with 2.8L you start it when its warm and it revs to 4,000rpm and stays. This truck has a carb. the throttle is not sticking.
Old Feb 2, 2005 | 09:51 PM
jimbo74's Avatar
something is out of adjustment, most likely the idle screw
Old Feb 2, 2005 | 09:56 PM
nightsurfride's Avatar
Look for vac. leaks as well.
Old Feb 2, 2005 | 09:59 PM
the_supernerd's Avatar
Make sure to check the fast idle adjustment also. There might also be a vacuum mechanism that is involved in the carburetor throttle position, so you should probably check for anything controlling the carburetor. There might be one that has a vacuum switching valve that is stuck or something similar to that. I also agree with checking the idle and vacuum leaks.
Ricu_air
Sep 19, 2015 05:35 AM
87SR5justin
Sep 15, 2015 06:48 PM
Longbed4Life
Sep 7, 2015 06:07 AM
shrek99352
Aug 31, 2015 04:16 AM
