Any thoughts on missing...
Old May 22, 2004 | 09:21 PM
radrex's Avatar
Here is an interesting problem --
I just rebuilt my 3vze - everything new. New Plugs, Wires, Rotor, Cap, O2 Sensor.
All vaccum lines hooked up properly.
Idle 800 rpm - Timing 10BTDC with jumper attached.
It idles like a dream. It accellerates nicely. Seems to run nicely at mid-higher RPMS. But under a load - at low RPM's Say a steady 40 mph -- it seems to be missing - or running roughly. It's got me thinking....
Anyone have a clue??
Old May 22, 2004 | 09:22 PM
radrex's Avatar
Oh yeah - all gaskets are new - Fuel Injectors cleaned and tested with new Rubber..
Old May 23, 2004 | 12:41 AM
Sunday BBQ's Avatar
Well, this may sound stupid, but maybe it's all in your head. It sounds like you have covered everything! Maybe it's just because it's under a load, and... well who knows, but if it only seems to be missing or whatever, and it doesn't seem like it's really a problem, I wouldn't worry about it. It sounds like you have everything covered. How does it feel like it's missing? When my old truck was missing... boy was it missing! My friend thought I was messing with him by letting off the gas and stomping on it very quickly and letting it off again, but it really was just me trying to drive normally. It turned out to be the plugs, wires, etc. (I had a 5spd so it was very noticable). Anyway...
Old May 23, 2004 | 04:45 AM
radrex's Avatar
Actually, it ran nicely before I had to rebuild everything due to a head gasket It replacement. It kind of lurches back and forth like it is missing or something - only at very low RPMs under a load - such as at about 40mph when it kicks into Overdrive.
I'm going to mess around and test the TPS and associated stuff today.
If that doesn't work I'm going to haul it up to the stealership for a diagnosis.
Sean McAuley
9
Nov 8, 2015 12:26 PM
RobotMoose
Sep 2, 2015 05:53 AM
priest16
15
Aug 6, 2015 07:43 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Edionne13
Jul 9, 2015 01:59 PM
