Amsoil fluid question
Old Jan 24, 2003 | 10:33 AM
Paul H.'s Avatar
I have decided to get amsoil for my diffs and transfer. My manual says to use SAE90 in the rear, but amsoil does not sell this. Can I use 75W-90 instead? This is for a 92. What does everyone else use?
Old Jan 24, 2003 | 10:55 AM
CTB's Avatar
CTB
Yes, 75W-90 in the front and rear diffs will work just fine, as well as in the transfer case. I can't remember off the top of my head what the transmission takes, but it should be in the owner's manual. Also, 80W-90 will work fine for the rear diff.
Old Jan 24, 2003 | 11:14 AM
rchavis's Avatar
On the transfer case, If it is an automatic, then it uses ATF.
Old Jan 24, 2003 | 06:46 PM
CTB's Avatar
CTB
Oh ya, good call. I was just thinking about my manual tranny-
Old Jan 24, 2003 | 08:38 PM
HBoss's Avatar
Mine's not a 2nd gen. however I thought I'd add my two bits in for you. I use Amsoil 75W-90 in both diffs & the transfer case.
No complaints.
Al
Old Jan 24, 2003 | 09:20 PM
Corey's Avatar
Co-Founder/Administrator
Ditto.
I run Amsoil 75-90 in both diffs, and Amsoil ATF in the transfer case.
And of course Amsoil 10-30 in the engine, and Amsoil ATF in the tranny.
Old Jan 24, 2003 | 09:55 PM
Sparman's Avatar
Is this the case for 3rd Gen Automatics also or only 2nd generations?
I hope not.....
Curt
Old Jan 24, 2003 | 10:09 PM
HBoss's Avatar
2nd gens only. 3rd gens use gear oil in the transfer case.
Old Jan 25, 2003 | 06:53 AM
Paul H.'s Avatar
Thanks for all of the replies guys. I'll order the amsoil today. BTW,mobil 1 cost the same as amsoil does down here. Thats why I'm going with amsoil. as well as the rave reviews.
Old Jan 27, 2003 | 06:03 AM
ravencr's Avatar
How about a 3rd Generation Transmission? Anyone know?
Chris
P.S. I just bought the Engine Flush, and 0W-30 Series 2000 engine oil for the first time. I'm excited to put it in.
Old Jan 27, 2003 | 07:29 AM
HBoss's Avatar
Chris
3rd gen transmission is still ATF fluid. It's just the transfer case that uses gear oil.
Al
Old Jan 27, 2003 | 09:37 AM
ravencr's Avatar
I've read Gadget's site about what type of flush system to use, and I was wondering if I should buy the equipment to do it or have a shop do it using Amsoil ATF? Anyone know where I can get the flushing system that he recommends: pump inlet flush machine. Thanks,
Chris
jasonty
41
Dec 23, 2018 01:00 PM
Up&Down
Aug 11, 2015 10:04 AM
Poppie51
Aug 2, 2015 11:29 PM
the1998sr5
Jul 16, 2015 06:20 AM
Poncho0206
Jul 10, 2015 06:21 PM
