Alarm/window module wiring help needed
Old Feb 29, 2004 | 06:56 PM
jtree007's Avatar
Unhappy Alarm/window module wiring help needed
I jsut installed (well in the middle of) an alarm for my Runner and the alarm is installed and works fine. I am trying to wire the rear window so that I can use the remote from the security system to move the window. The security system I have as 3 extra channels, 2 are pusled and the other one is a constant( runs as long as I have the button down). I have a DEI 530T window module to control the window but After wiring it I have not been able to get the module to effictly move the window via the remote nor the in cabin switch (is moves in incraments and not consistantly. I am not going in to how I have it wired as I know that it is sorta right, but mostly wrong ( I know the gorund leads, power lead, and option lead works...that is all I am sure of at this point)
Can anyone give me some pointers or better yet what wires I need to use and where I can find them... I really need to get my Runner back together soon.
Thanks,
Parts I have... Prestige APS-410S Alarm system... DEI 530T Window module.. Power everything on a 94 runner...
Old Feb 29, 2004 | 07:29 PM
MTL_4runner's Avatar
Thanks,
I don't know the answer but post it over at www.the12volt.com
That site is THE BEST for car alarm install stuff!!!
You may even find the answer just by doing a search over there.
Old Feb 29, 2004 | 08:04 PM
Cebby's Avatar
You need alot of juice to move that rear window. Even when mine was working right, it was unable to roll the rear window the whole way up. I'm not sure if mine has a 530 or 540 on it. I'll pull a panel tomorrow to see. Mine uses the EXT that is constant, not the pulsed one.
I can roll it down with the remote, but have it setup to roll up only when armed (not via EXT function)
Old Feb 29, 2004 | 08:06 PM
Cebby's Avatar
Here's the page you want:Linky
Old Mar 1, 2004 | 10:12 AM
jtree007's Avatar
should I acess the wires at the switch ot is there a controler somewhere
Old Mar 1, 2004 | 02:06 PM
Cebby's Avatar
Mine has the wires spliced in at the driver side cargo cubby.
Old Mar 1, 2004 | 02:25 PM
jtree007's Avatar
Thanks... exacly what I needed.. Could use more inf if anyone has it but that is what I needed to know.. I had no idea where the conroler was...
5280jo
10
Jul 13, 2015 10:05 PM
BigArt70
Jun 30, 2015 09:51 PM
LSUMatt1514
60
Oct 10, 2003 12:30 PM
HALMAN
Jun 14, 2002 09:02 PM
