Aisin manual hub conversion
Old Oct 27, 2009 | 03:03 PM
crolison's Avatar
Originally Posted by Mrbikerman
So I went to denver and picked up two spindles and two half shafts from an 01 4cyl taco. They look the same as my add on the outer part of the hub, but thats OK right? Guy at the shop said they're non add. They have green axles like my Dad's 98 4cyl. I'll be putting in the manual hubs sometime this week and let you guys know what happens.
Car-part.com is where I found mine, they claim to have some that are ABS w/o add but they're farther away from me than denver. Thanks again Crolison!
like the outside of the spindle should not look the same. It should have studs on it for the hub.
The cv's should not have threads for a bold on them
Old Oct 27, 2009 | 09:49 PM
Mrbikerman's Avatar
I think theyre auto hubs :(
The axles are still connected to the spindles, so I can't see the shaft that is supposed to have or not have the threads on it. The hub assembly doesn't have studs for a hub, it has a black plate just like my ADD.
This place advertised them as ABS w/o add, then they told me they weren't abs before I drove an hour to get them, but assured me they were manuals. Then I drive 3 total hours to get these things and I'm too retarded to get the right ones. I just did what I was afraid of: making a stupid ass mistake because I cant find the right information about it. Everyone tells me to search search search and the only stuff I ever find is about the ORS or Downey conversion kits. Nothing about swapping from a tacoma w/ manual hubs. If I could find some pictures, or even better just find a damn kit (I dont care about the money at this point, I just need manual hubs ASAP, and yes I have checked the classifieds) Now I'm 350 in the hole...
Old Oct 28, 2009 | 04:09 AM
crolison's Avatar
Go return those pos's
The ones you look like are these
Old Nov 9, 2009 | 04:55 PM
Mrbikerman's Avatar
What the hell are these things
Ok I ordered some Manual hub spindles from pans auto. Got em today and they also do not have the studs for a manual hub. They look like they are ADD with the center caps removed. They advertise these as manual hubs seperate from the auto diff disconnect ones. Do u really have this bad of luck or is there some piece that presses in that has the studs for the hubs?
Old Dec 28, 2009 | 10:17 PM
  #25
Elton's Avatar
ok now that i ripped a cv boot ... soo if i want to do the manual hub and i could care less about front abs last 2 trucks have had none could i just go to a junk yard get the hole spindle get some new cv's and just bolt it in ?
Old Dec 29, 2009 | 06:30 AM
  #26
jdmaccord6's Avatar
for the most part, and don't forget the manual hubs too.
Old Dec 29, 2009 | 09:12 AM
  #27
Mrbikerman's Avatar
Anyone know where I can find these parts? Ive tried carpart.com with no luck, and there aren't any around my area, is anyone selling?
Old Dec 29, 2009 | 02:11 PM
  #28
Elton's Avatar
wont having no front abs cause the light to stay on maybe i should just replace the cv's and look into this mod later on
jaretstuff
Aug 4, 2015 02:08 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
PlayAwhile
Jul 20, 2015 11:36 AM
ItsJustD
Jul 7, 2015 07:49 AM
