airbags instead of coils!
Old May 25, 2005 | 11:05 AM
Eric's Avatar
I was talking to another 4runner owner about his version of fixing his saggin 2nd gen.... he poped the springs out, welded a airbag plates and shoved some airbags that he used to have on his mini truck in the spring location.
Now I know we are all pro-rock crawlers here, but if your not, and only do trails (old forest roads) what are the negatives to using airbags instead of springs?
I was thinking about how much I load up the rear of my 4runner, and the bags could be perfect to keeping the truck from sagging
Old May 25, 2005 | 12:43 PM
Unhappy99's Avatar
Airbags are great, unless they leak. Several of us here have airbags inside the coil springs and pump them up for towing. One of mine is now leaking after 3 years.
Old May 25, 2005 | 12:47 PM
jimbo74's Avatar
it wount articulate very well and i could see blowing a bag..... inside the coil would be fine though, for occassional heavy laods... however i wouldnt trust a rubber bag to support a vehicle all the time
Old May 25, 2005 | 01:34 PM
Albuquerque Jim's Avatar
Actually they can articulate if cross linked...as far as using them full time. Semi's do...
Old May 25, 2005 | 02:11 PM
jimbo74's Avatar
he isnt talking about air shocks, hes talking about air bags... unless you get the insane huge triple stack ones, there wont be much articulation at all, there jsut isnt enough room to do so... even with crosslinking..... bigrigs dont have much suspesnion travel and they arent meant for offroad... the oens that are setup for offroad, use actual leaf springs packs.....
Old May 27, 2005 | 12:02 AM
Eric's Avatar
I've seen the ones that go inside the springs, but this dude just took two bellow bags, welded a plate on the bottom spring perch, mounted something on the top (sorry I forgot the name, not big in the airbag lingo) and shoved them in, completely eliminating the springs
he had them cross linked, and said the anti-roll bars do a fine job of keeping the car from rolling around too much, however I would be a bit sceptical.
another thing he mentioned is that tripple bellow bags have 18 inches off lift crosslink those puppies, and you'd have no problems with articulation!
I'm going to stop buy the shop he works at tomorrow, I'll try and grab some pics
Old May 27, 2005 | 12:06 AM
jimbo74's Avatar
yeah until you articulate it until the bag blows... then what? you dont have a suspension to support itself.... talk about 3 wheel motin.... except one wheel smashed into the fender
Old May 27, 2005 | 05:30 AM
MTL_4runner's Avatar
The airbags are a bit more durable than you might think (they have been used on production cars/trucks).
Here is an example of an install:
http://www.fourwheeler.com/howto/80258/
http://www.overlander.com.au/pg/equipment.php?id=29
Old May 27, 2005 | 07:04 AM
ravencr's Avatar
Why don't you get a set of Monroe Max-Air shocks instead that will help you with the sagging rear end and help carry additional loads too. I just bought a set from Advance Auto today, because after moving my gas tank to the rear spare tire location and towing my trailer with my ATVS on it, it's almost to the bumpstops. I'll be installing them today, so we'll see how much they help. I got the MA700's, which are comparable in length to the OME N86 Firms, which is what I have now.
Chris
Old May 29, 2005 | 01:27 PM
Eric's Avatar
INMO shocks should have nothing to do with supporting the vehicle, they should only be used to dampen.
Old May 29, 2005 | 02:17 PM
waskillywabbit's Avatar
Guy at work does all the airbag stuff, he has a dualie w/ them on there to raise/lower the rig, they are the rear suspension and his still rides, tows, does everything...sits at normal level (or wherever) when driving around, but sitting in the parking lot, it is on the ground...
Airbags for just riding around, sure...
Airbags for wheeling, no...
Old May 29, 2005 | 04:48 PM
grandmasterE's Avatar
Don't you guys remember the first rock buggies? The Sniper by avalanche engineerging had air bag suspension front and rear.
Also, about airbags supporting the vehicle all the time...every highway tractor runs solely on airbags...and have for years...I'd say they've proven themselves reliable.
Old May 29, 2005 | 06:00 PM
Ironmike4x4's Avatar
If you're gonna go through all that trouble and still want to go offroading, why not just go for some type of hydraulic unit? I know that some company just recently tested some sort of hydraulic suspension setup on jeeps, I think I read it somewhere in 4wheel and offroad a few months back.
Old May 29, 2005 | 06:05 PM
93ToyKid's Avatar
The only thing that would concern me would be a severly misplaced stick or something that gets hung around the tire and punctures the airbag while on the trail. Very unlikely, but it could happen.
Old May 30, 2005 | 02:06 PM
ravencr's Avatar
Well after driving 5 hours to our camping spot without the shocks installed, I installed them while camping and the drive back was totally different. Instead of sitting on the bump stops, I now ride 4-6 higher than them, and the ride is perfect. I'd highly recommend the Monroe Max air shocks if you have a sagging rear end.
Chris
Old May 30, 2005 | 02:07 PM
I hope I'm not playing the devils advocate too much here..but that same stick could easily dismount your coil spring (under the right freaky-deaky circumstances, assuming you installed the airbag in the factory coil location). It would be a heck of a lot easier to install a new airbag on the trail than to reseat a coil.
And besides...I'm sure most of you actual wheelers have seen many leaf springs break over the years. That's never convenient. An extra airbag would be small to carry, light, and easy to chage.
I hope I'm not pissing anyone off here, but I just like to see new ideas in action. I realize that newer doesn't mean better, and that for every 10 ideas 1 might be useful, but if someone wants to try it, lets wait and see their results, and offer as much help as we can along the way.
Old May 30, 2005 | 03:18 PM
CynicX's Avatar
I know a guy who had a bagged Jeep Rubicon on 36's I think. They were designed for offroad. He could lower it down for the street and jack that thing WAY up for offroad. It was like a monster truck. Not only did he not have problems he faired better then people with lifts on 35+ tires.
Only problem with them is that its just something else to break and alot of components.
Old May 30, 2005 | 06:10 PM
Ganoid's Avatar
It will never work!! (Ohh and BTW the sky is falling)
\/ \/ \/ \/ (not mine) \/ \/ \/ \/
Ohh did I mention those are 37's
Old May 30, 2005 | 07:45 PM
I think I remember seeing that truck before. I'm quite impressed by the flex.
Old May 30, 2005 | 07:59 PM
CynicX's Avatar
be neat being able to lean the truck....could take on some interesting terrain at interesting angles if you could lean the weight
