Airaid MIT & True Flow filter
Old May 11, 2007 | 08:24 AM
  #41
Motayota's Avatar
Just installed the Airaid MIT yesterday, and there is a real diffenence in throttle response, especially in 2nd, 3rd on my auto. I also lost this weird engine rumble/vibration when topping out on those gears, probably due to the other intake tube with that airbox thingy.
The True Flow will be arriving on Monday, can't wait to see if that improves things also.
All in all a good mod.
Luis
Old May 11, 2007 | 06:29 PM
  #42
BennyTRD's Avatar
Originally Posted by rocket
NGK = OEM.
Every other wire and plug manufacture should be avoided.
Are you sure?? My 97 has stock wires and they are Sumitomo. I have seen dyno tests that prove that Sumitomo wires are provide a better spark than an aftermarket $150 set of MSD's.
Old May 11, 2007 | 06:43 PM
  #43
BennyTRD's Avatar
Luis
I went and got the True Flow kit from Jason B (Thanks a bunch!!), and installed it the other day. I have to say the but dyno says theres something there. How much?? Not sure. I was hoping my Auterra software that I ordered would be in before I put it in but I couldn't wait any longer. The box was starting at me and I had no choice.
Its alot louder than I expected. Around the 4000RPM range its got sort of an angry snort, but for everyday commuting you don't really hear that much. Could be in part to having the deck plate open. All in all its a very nice and simple kit. Installed in 10 minutes. I am going to re-install the stock intake, and get a baseline for power, then install the True Flow kit again, and test again. See what I come up with for numbers to justify the cost of the kit.
Old May 12, 2007 | 10:30 PM
  #44
Jason B's Avatar
Nice pics
Old May 13, 2007 | 06:13 AM
  #45
BennyTRD's Avatar
Originally Posted by Jason B
Nice pics
That was quick Jason!! Thanks again!!! Can't wait for the hood shocks!!
Old Feb 19, 2009 | 09:35 PM
  #46
Jason B's Avatar
Bladt from the past, but have these in stock again. This WILL help with gas mileagem, I guarantee it.
http://www.burtmanindustries.com/zoo..._truflo_int_96
Old Feb 20, 2009 | 12:21 AM
  #47
TC4RNR's Avatar
first, this thread is realy old.
JB, isn't basicly an ISR mod? i mean the tube part.
Old Feb 20, 2009 | 07:32 AM
  #48
Jason B's Avatar
It's larger diameter, more flow, mandrel bent, black powdercoated steel and comes with a true flow filter.
Old Feb 20, 2009 | 03:08 PM
  #49
22R-to-5VZFE's Avatar
where is reputable place to buy JUST the Airaid MIT at??
I already have a K&N Filter and 6" deckplate mod...
Old Feb 20, 2009 | 07:59 PM
  #50
Jason B's Avatar
Here you go, we sell that too. IN STOCK.
http://www.burtmanindustries.com/zoo...n_airaid_96_02
Old Feb 21, 2009 | 03:11 AM
  #51
ARB1977's Avatar
I had the MIT and deckplate mod for about 4 years with a TRD airfilter. Recently i closed it and did the elbow mod with a AFE Pro Dry filter...alot better sounding, much quieter.
Old Feb 23, 2009 | 03:46 PM
  #52
Godzilla's Avatar
What is your opinion of the AFE dry filter so far? It looks like a miracle drug in a sense, and am considering purchasing one.
Old Feb 23, 2009 | 03:57 PM
  #53
Thanks I just ordered one...can't wait for it to arrive!!
Old Feb 23, 2009 | 04:02 PM
  #54
Fink's Avatar
Wow, JB.
You sure did pick an oldie!!
I had both the Airaid MIT and True Flow filter on my '99 4Runner and loved them both.
The MIT along with the deckplate mod really did help performance, not a big improvement in gas mileage but more power for same mileage - can't beat that.
Fink
Old Feb 23, 2009 | 06:45 PM
  #55
j-money$$$'s Avatar
what up with the airaid mit tubes online they say the fit 99-02 4runners. as far as i knew a 3.4 was a 3.4 so wouldnt it fit my 97 sr5. can someone clarify this
Old Feb 23, 2009 | 07:04 PM
  #56
Godzilla's Avatar
Read;
https://www.yotatech.com/forums/f2/i...nsider-117184/
Old Feb 24, 2009 | 07:44 PM
  #57
j-money$$$'s Avatar
gracias mucho man that makes sense
Old Feb 24, 2009 | 08:42 PM
  #58
Jason B's Avatar
Here are links to BOTH for the best combo
http://www.burtmanindustries.com/zoo..._truflo_96u_v6
Old Feb 27, 2009 | 01:10 PM
  #59
Just installed the MIT, I dig it! Quite a bit louder and deffinately smoother acceleration on light acceleration...should help with MPG I am thinking...WOT I cannot tell a difference...but sounds good...cheers!
Old Feb 27, 2009 | 05:20 PM
  #60
Fink's Avatar
Glad it worked out for ya, you might see a slight increase in mileage but I doubt it to be hones.
Have you done the deckplate? If not, I highly suggest you do it - it will make the Airaid shine.
Fink
