Adding a sub amp to stock stereo?
I'm planning on using a line out converter. Where do you tap into the speaker wires? And which colors are rear left & right?
I found the diagram about an hour ago or so http://www.modifiedlife.com/2000-toy...iring-diagram/ , but it's not exactly right. I've been checking the wires with a tester. So far, blue is constant, gray is acc, violet is illumination, and that's about it. I know brown is usually negative, so I have to figure out what's what in the remaining 8 wires.
theking11863
Mar 19, 2016 09:36 PM
Esibnitsud
Jul 30, 2015 08:19 PM
