Adding PIAA Fog Lights to 2001 4Runner
Old 12-30-2007, 05:43 PM
sportzkat's Avatar
Got a set of PIAA fog lights off eBay and want to add them to the fog light holes in the valance of my 2001 4Runner. I know that I will have to make a bracket to support them, but I'm curious about the wiring. I don't want to wire them directly to the battery, but I was wondering if I could utilize the wires hanging just behind the vacant holes in the valance. These have a white plastic plug on them and I assume are there to plug in the factory lights (if you had them...). Can I use them? If so, what do I need to do? I'm kinda of an electical noobie so don't spare any details thinking you might offend me...you won't! Lastly, there is not a fuse in the fusebox for the fog lights. I assume that if I use these wires I'd have to add one??
Thanks a ton for any assistance any of you can offer. I really appreciate it.
Old 12-30-2007, 06:22 PM
frodin1's Avatar
Yes, if you have the plugs there for the factory foglights you should be able to use them for aftermarket ones. As long as the load is close. I mean wattage. I'm running aftermarket higher wattage bulbs in the factory fogs and I'm not having any issues.
Old 12-30-2007, 07:29 PM
TRDrunner's Avatar
i believe the factory fogs are 55w.
if you ran a bit higher you should be fine.
Old 12-31-2007, 09:09 AM
sportzkat's Avatar
Thanks for the info. If you don't mind, I have a few follow-ups:
- To use these wires, I just snip off the factory plug and wire directly to the lights, right?
- Do I need to put the fuse in the box for the fog lights before they will work?
- Are these factory wires tied to the headlights in anyway? In other words, are they only hot when the headlights are on? Low beam only?
- How do I wire the switch when using the factory wires?
I'll check the wattage on the bulbs because I'm not sure about that.
Thanks again for the help. I really appreciate it.
Charecter1
11-06-2023 10:08 AM
06-01-2021 01:51 PM
Yota.Jay
07-23-2015 08:08 PM
Suprarossa
07-06-2015 05:21 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Adding PIAA Fog Lights to 2001 4Runner
