Adding margin for SC'd 4runners
Old Jun 18, 2003 | 06:52 PM
AJatx's Avatar
Water injection for a supercharger application:
http://www.aquamist.co.uk/cp/cp.html
It'll reduce the chance of detonation and could add margin to your fuel delivery system.
I suggest a decent ignition amplifier modification.
It's something I would add if you have detonation with the stock pulley or upgraded pulley.
Great feedback from the turbocharged guys on DSM and Mazda forums.
The 2D system is plug n play with it's own map.
The 2S is a fully programmable kit that requires some tuning.
J
Old Jun 18, 2003 | 07:10 PM
HaveBlue's Avatar
I looked into an Aquamist system a while ago but never actually followed through.
The biggest issue is where to put the water injector. The water would have to be introduced AFTER the impellers.
I had a few local hot rod shops look at my engine and they said they could either tap into the housing after the impellers or fab a spacer with the injector to place between the blower and the intake manifold.
Like I said, though, I never followed through.
Old Jun 18, 2003 | 07:54 PM
ravencr's Avatar
Ajatx,
Are you planning to do it? There are a few of us discussing this option as a great way to run a 9 psi pulley without the negatives and the potential for 300+HP to the wheels. What did you have in mind? What generation S/C are you running?
Chris
Eggslinger
Jun 8, 2019 03:32 PM
Yota.Jay
Jul 23, 2015 08:08 PM
timmJ
Jul 7, 2015 02:01 PM
Suprarossa
Jul 6, 2015 05:21 AM
HRDC0R19
Jul 5, 2015 06:43 PM
