AC condensor on a third gen.
Old Oct 19, 2006 | 02:15 PM
harpen123's Avatar
I just nicked my A/C condensor with an angle grinder accidentally when doing some trimming, its about to begin to get cold here and i was wondering if waiting to replace this and leaving the hole open will ruin any other components ofthey system.
Old Oct 19, 2006 | 03:32 PM
X2and4X's Avatar
Well if it leaks out, the rest of the system should still be ok. It should have a switch that doesn’t allow the compressor to turn on if the charge is to low.
Old Oct 19, 2006 | 05:17 PM
mpavolka's Avatar
they make radiator and condensor sealer. It is just like glue that covers up nicks like that. I would go to an auto parts store and buy some to limp your system through the winter rather than it leaking.
Old Oct 19, 2006 | 06:00 PM
harpen123's Avatar
its a pretty decent nick the angle grinder was shooting sparks into my eyes and i really was being careless its probably a quarter inch deep. U think it still might work.
Old Oct 20, 2006 | 06:31 AM
Finelygotone's Avatar
Did the AC system leak refrigerent out of the nick? If it did blow the charge, at the very least you should clean the area really well and epoxy it until you can replace the condensor. An AC system left open to atmosphere through a hole like that is not good. Moisture can ruin the system by causing internal corrosion.
Old Oct 20, 2006 | 10:53 AM
MTL_4runner's Avatar
Ditto, do not just leave that open to the air all winter or you may find you need a bunch more stuff replaced to get the system going again later. At the very least seal the system shut to the outside air (silicone sealant would probably work best). Then just replace the part in spring.
mussy01
Dec 13, 2016 08:20 PM
icentropy
Sep 10, 2015 05:03 AM
landrunner
Aug 5, 2015 09:18 PM
anniesball
Jul 29, 2015 11:46 AM
Stump1883
Apr 22, 2003 12:10 PM
