98 tacoma leaking oil behind crankshaft pulley.
Old Feb 28, 2013 | 11:36 AM
mlawrence17's Avatar
I've got a '98 tacoma prerunner with 140,000 miles. Its leaking oil behind the crankshaft pulley. I'm assuming there's some type of crankshaft seal that needs to be replaced. My plan was to replace the three belts and check out the timing belt....or should I just go ahead and replace the timing belt since I'm half way there? What about the water pump? Anything else? Someone recommended this kit.
http://www.ebay.com/itm/Toyota-TIMIN...item2a144a37e8
any thoughts??
Old Feb 28, 2013 | 11:59 AM
rworegon's Avatar
Excellent kit.....many here, including myself, have used it.
Do it all while you are in there. Buy a new crank bolt from the local dealer as it is a non-reusable part.
There are a couple of other 3.4 timing belt threads in past 2-3 days.
Old Feb 28, 2013 | 03:34 PM
98SR54RUNNER's Avatar
Came to say this.
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
jakebarrett
Jul 10, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
