98 taco speed governor
Old Mar 23, 2009 | 07:37 PM
racingcameron66's Avatar
hey guys I got a 98 taco with the 22re m5 trans., look in the sig for mods, I do a Lil bit of interstate travel so i need to do aleast 85ish at some times. so here’s what my prob is, my speedo is like 30 off ex. 90 on the speedo is 70mph. and my truck cuts off when the speedo hits 105 so im only goin like 80 when it cuts off. is there something i can do to not make the governor "not work" and i know i can calibrate my trans but that takes $, and im a broke a$$ collage student so yea.
Old Mar 23, 2009 | 07:58 PM
crolison's Avatar
you don't have the 22re, you have the 3rzfe.
get a new tcase speedo gear, should be cheap fix.
what gear ratio did you originally come with. Are you sure its off that much? mine is only off 2mph with 4.88's.
Old Mar 23, 2009 | 08:07 PM
mastacox's Avatar
The only way your speedometer would be indicating 90 when you're only doing 70 is if you were running 23" tall tires (assuming your speedo was correct with 30" tall tires).
You see, your speedo would read faster if you were running smaller tires or much lower gears with stock tires. So, which is it? Did you fail to mention you regeared to 5.29's while still running your stock 30" tires? If you are running 33" tires and stock gears, your speedo will be reading 10% SLOWER than actual, which means 105 indicated is actually 115mph, unless there's something wrong with your speedo.
Old Mar 23, 2009 | 08:17 PM
98runner210's Avatar
or maybe he wants to go faster than 100 without being flamed....
Old Mar 23, 2009 | 08:23 PM
mastacox's Avatar
Sounds like a pretty terrible idea, especially since 33x12.50r15 Summit Mud Dawgs are only "R" speed rated, which is 106 mph.
.. plus you know, it's a 4wd (I assume) Tacoma, not a performance coupe
Old Mar 23, 2009 | 08:27 PM
Mic09dcsm's Avatar
Originally Posted by mastacox
Sounds like a pretty terrible idea, especially since 33x12.50r15 Summit Mud Dawgs are only "R" speed rated, which is 106 miles per hour.
Why should that stop him? I've seen a lifted F-250 with 40's and a trailer smoker and he was going 105 at least.
Old Mar 23, 2009 | 08:29 PM
mastacox's Avatar
You're right, that's a perfectly good reason. What was I thinking.
Old Mar 23, 2009 | 08:40 PM
Mic09dcsm's Avatar
I don't know, that you're being facetious and don't get the point maybe?
Old Mar 24, 2009 | 01:54 PM
no i have 4.88 gears and 33's and im right.....90(on tha speedo)=70 /60(on tha speedo)=45 and why would you flame me even if i wanted to go over 100?
Old Mar 24, 2009 | 03:45 PM
bump********
Old Mar 24, 2009 | 04:18 PM
mastacox's Avatar
Well you have your answer- there is no cheap solution. The best option is to recalibrate your speedo with a new gearset. URD used to sell a speed limiter defeater box, but they have since stopped (possibly due to legal issues). It wouldn't have been cheaper than a speedo gearset anyway.
I'm curious why your speedometer is reading so fast though What was the stock gear ratio in your truck, 4.10's?
Old Mar 25, 2009 | 11:56 AM
nah it was some goofy set like 3'somthings (3.23's maby?)im not real sure but they were super high. but theres not wire that i can just cut ? idk if my speedo reads right.
Old Mar 25, 2009 | 02:46 PM
so i guess no one knows?
Old Mar 25, 2009 | 04:46 PM
crolison's Avatar
3.58 is the crappiest gear ratio you could get
cheapest way is speedo gear, go to a junkyard and get one.
Old Mar 25, 2009 | 06:49 PM
what speedo gear?
rodskwad
Aug 12, 2015 02:33 AM
rap2me
Aug 11, 2015 05:03 PM
Crgrey42
Aug 10, 2015 04:23 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
ripp96
Jul 25, 2015 02:32 PM
