98' Taco 4cyl Rear Third Member R/P ?
looked at my buddy's 2.7L 1998 Taco-
The Taco third has better gound clearance at the u-joint. I was wondering if it was an 8" like the earlier trucks/runners, and if the housings were interchangeable? The unit would make front drive line angles better on SAS'd rigs, and might be cheaper to get than a true hi-pinion--------
later
later
if the drain plug is on the right side, i believe that it is the 8.25" diff. the only tacomas that have the 8" diff have the E-Locker, so if he has the E-Locker then he has the 8". otherwise it should be the 8.25" someone correct me if i am wrong
-Casey
-Casey
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
