97 Tacoma will not start, wierd buzzing sound
Old Dec 14, 2009 | 04:30 PM
survivorman97's Avatar
So I had just finished changing my oil and had ran it to see how much more I needed to add and what not and I turned it off and was listening to some tunes. Then I go to start it again and it sounds like its going to start up fine like usual and then about 2 seconds into cranking it just stops trying. The dashlights went kind of dim and then there is this electronic buzzing sorta noise coming from the drivers side dash every time I try to crank it. NO CRANKING whatsoever just the buzz, sounds like those buzzer doorbells kinda. Please HELP! I checked the battery and it appears fine. What can I do?
Old Dec 14, 2009 | 05:11 PM
Also I just remembered that a couple of weeks ago i changed out my fuel filter and in that process I had to disconnect the circuit opening relay, near right under the gauge cluster, to relieve the fuel pressure according to my repair manual. Maybe a fuse or something?
Old Dec 14, 2009 | 05:20 PM
jason191918's Avatar
dead battery?
Old Dec 14, 2009 | 05:37 PM
SchooBaka's Avatar
sounds like either a dead battery or bad connection at the terminals. What voltage is the battery reading?
Old Dec 14, 2009 | 06:30 PM
I have a battery charger that says its reading at 12volts but Im not so sure about that thing. How else can I tell? I thought if the battery was done it would click rather than buzz. I just had never heard it make that noise before and it just up and quit all the sudden like, seemed weird for a battery to do. Does that happen sometimes, them seeming healthy and then having practically no power?
Old Dec 16, 2009 | 02:30 PM
Just got my new die hard battery put in and yep that was it... I feel kinda dumb, I should have known. Thanks
Old Dec 16, 2009 | 02:33 PM
brian2sun's Avatar
Glad you got it fixed.
Regency
20
Jan 3, 2020 07:43 PM
vasinvictor
Jan 20, 2016 12:39 PM
Jnkml
Jul 6, 2015 01:20 PM
88Toy
Jul 4, 2015 02:11 PM
gog1968
Jun 22, 2015 05:55 AM
