96 Taco 3.4 Possible short caused PO340
Old Nov 20, 2022 | 05:20 PM
Crashly's Avatar
Hello everybody, I was hoping that you could point me in the right direction. I had a aftermarket lighting wiring harness short under the battery directly to the body.. I had the lights on when they went out and about two minutes later the truck shut down. In order to restart I have to crack the throttle body open and hold it open by hand. Sometimes it will run for a few a couple of minutes up to 2k rpm. It is also running really rough. As soon as I put it in gear it dies. I pulled the code and it has a P0340, I know that there are a few things in this circuit that I may have damaged with the short. At this point I have replaced the CPS. Can any body shed some light on what I should check or replace next?
Thanks for your help
Roadrunner
Apr 4, 2017 07:24 AM
riptide
Nov 4, 2011 03:49 PM
hamish_18
3.4 Swaps
Feb 10, 2011 09:13 PM
boraxman
Nov 22, 2004 08:08 PM
