'96 4Runner runs rough and rich OBD-II
Old Jan 15, 2008 | 08:53 PM
RTB's Avatar
RTB
I need a little help tracking what exactly my problem is. The vehicle is a 1996 4Runner, 3.4, 5spd, 4x4. The 4runner was wrecked (right front damage) but still ran great, and while fixing it I decided to swap in the lower mile'd 5VZ-FE from my '99 donor 4Runner. I kept all elec off the 96 engine except the newer style MAF and air-box.
now it isn't running so great.
OBD-II codes:
100 (MAF circuit)
101 (MAF actual input different from actual)
110 (IAT sensor circuit)
1300 (Igniter circuit)
SYMPTOMS ARE:
Starts and dies
will start and high idle on second or third try
warms up and idles down to 750rpm (slightly rough sometimes)
throttling slowly it revs smoothe
hitting the throttle bogs down (and it stays bogged until I let off)
exhaust is strong smelling and leaves carbon mark on driveway under tailpipe
I can drive it if I'm easy on the throttle, but if I get into ANY hurry at all it's gut-less
WHAT I'VE DONE, OR KNOW SO FAR:
cleaned MAF w/ elec cleaner
cleaned throttle pos sensor (tried the spare)
cleaned throttle body (tried the spare)
checked for vacuum leaks
checked for any loose wires or bad grounds
Compression check (180+ on all 6cyl)
new NGK plugs
I'm wanting to say this is a wiring issue. Any ideas? Is there a possability of an issue in the fuse block? Maybe resetting the ECU? (I did try to clear the codes on the OBD-II)
thanks for any input
Old Jan 15, 2008 | 09:16 PM
toytech76's Avatar
Your pins on the maf are different now since you are still using the 96 harness and ecu. Get an EWD and switch the pins around to the right spots
Old Jan 15, 2008 | 10:11 PM
ninjarunner's Avatar
x2 what he said.... it will run great then
Old Jan 16, 2008 | 03:04 AM
MTL_4runner's Avatar
X3
Definately MAF pinout problem.
Old Jan 16, 2008 | 05:00 AM
RTB's Avatar
RTB
MAF pinouts
that.... would be awesome.
I did try swapping back to the 96 intake tube and MAF to see how it would run. It ran better, but still not great (but none of the codes were reset at).
I'd still be using the old style MAF- but the 96 air box was crushed in the wreckage
thanks- I'll post outcome (might be this weekend)
Old Jan 16, 2008 | 02:39 PM
RTB's Avatar
RTB
Problem solved
Yeah that was it. 4 of the 5 wires were in the wrong spot- amazing it ran at all.
Thanks for the info
Old Jan 16, 2008 | 04:49 PM
Thanks for the info
It would run the same as if the MAF was unplugged.
......which is pretty bad, but it will run nonetheless.
Yont283
Sep 23, 2022 08:06 PM
puffin04
Jul 10, 2015 09:17 PM
87blyota
Jul 1, 2015 05:26 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
