96 4runner E-locker mod: I want to be able to use it whenever.. HELP!
Old Jun 1, 2009 | 11:39 AM
Tacoclimber's Avatar
Originally Posted by jvh4513
I geared my question so that it wouldn't matter the color of the wire.. I was just asking what I actually do to the wire..
accoutrements... that's a new one
I'm trying to remember what I did to the grey wire on my Taco. It's been over 4.5 years.
I think you just cut the wire and then ground it...but don't quote me on that. I don't want to be responsible for an
Old Jun 1, 2009 | 11:43 AM
scuba's Avatar
Cable Locker Conversion (79-04 Rear End.)
41200-R74
All SWB Pickups & 4 Runners
$259.95
Old Jun 1, 2009 | 11:50 AM
For the life of me, I can't figure out why Downey would state that having an electric actuator in the front would be a bad thing, especially in light of the factory lockers in the rear having an electric actuator.
Anyone wanna comment on that?
Old Jun 1, 2009 | 12:32 PM
neilan's Avatar
If you read the caption on downey it explains it fairly well.
It is susceptible to damage from rocks when wheeling and breaks fairly easily. The electrical components dont like water, dirt and any force applied to them. The cable locker is "stronger" and less prone to failure. But many people who have actually tried to cable locker will tell you that they suck because the cable is not a close system. Dirt and water in the cable make it very difficult to shift. And the cable can limit articulation.
Old Jun 1, 2009 | 02:31 PM
  #25
Teuf's Avatar
the front was a short pull lever ,,,? yes,,, if so i'd use that in back
Old Jun 1, 2009 | 03:44 PM
  #26
I guess that's the point I was making. The cable system is just as limited.
Seal your electronics, and get a motor shield for the actuator. Problem *relatively* solved.
Old Feb 4, 2010 | 01:16 AM
  #27
thedude42's Avatar
wow! i have been really thinkin about doing this myself, it sounds easy enough
anybody think of any snags i might run into? or anything that i should pay close attention too?
Old Feb 4, 2010 | 05:23 AM
  #28
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
You just cut a wire and ground it, not too much else to it.
Just make sure you cut the right wire.
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
AaronM
Jul 8, 2015 07:15 PM
