95 taco 5 speed hydraulic clutch prob
Old Sep 21, 2015 | 07:27 PM
BigHoss_27's Avatar
I was told the master and slave were still good as long as there was no leaks clutch is sponge and let's all way out 1 inch off floor and I bled it to day and still nothing has changed with foot on floor it will eventually let itself back out and every now and again it will just go to floor
Old Sep 21, 2015 | 07:35 PM
Terrys87's Avatar
A leak is not always a sign of a bad cylinder. Brake fluid is harsh on the rubber seals so if the fluid is leaking past the cylinder, basically the same effect that you are seeing. You using part store replacement parts? Numerous threads on them failing. Stick with Aisin replacement parts.
Old Sep 21, 2015 | 07:44 PM
BigHoss_27's Avatar
I figured something was wrong with either the slave or master but 10-4 on oem parts the one on it lasted 292xxx might be time for a replacement anyway
smthwsn357
May 1, 2024 07:28 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
ripp96
Jul 31, 2015 11:14 AM
ripp96
Jul 25, 2015 02:32 PM
1996Taco
Jul 20, 2015 12:02 AM
