'95 T100 axle housing-'90 4Runner gears (4WD)
Old Nov 10, 2005 | 12:01 PM
90toyrunner's Avatar
I have read mixed opinions through online searches, thought I'd ask here. Can I use gears from a '90 4Runner in an axle housing for a '95 T100.
I have the gears that I need and can get an axle housing for cheap, but can I use these gears in the T100 housing? I have read on some sites that I can....that the T100 is essentially a 8" rear end and they use the same gears as the older V6 4Runners/trucks. However, I read on another site that it is an 8" rear end, but they are not interchangable.
Does anyone know the correct answer? I have been told in the past that parts are not interchangable by Toyota, just to take the risk and find out that they are. I guess I want to be sure in an uncharted (by myself) territory.
Old Nov 10, 2005 | 12:03 PM
Also, are all axle housing the same or is there a 4WD housing and a 2WD housing?
Old Nov 10, 2005 | 03:10 PM
init6's Avatar
The T-100 has the "8.4" diff. The 4runner uses the 8 inch diff.
The left shows the 8.4 gears, and the right show the 8 inch gears. The 8.4 gears has 12 bolt holes, and the 8 inch gear has 10 bolt holes. Both gears are 8 inches, but people call the T-100/Tacoma/Tundra diff the 8.4 diff. The 4runner uses the V6 diff.
Here is a good web page:
http://home.4x4wire.com/erik/diffs/
Old Dec 2, 2008 | 04:43 PM
JPautsch's Avatar
Hey what grear ratio does a 93 t100 have?
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
vasinvictor
Jan 20, 2016 12:39 PM
Gamble_STi
Jul 1, 2015 12:51 PM
streetuner15
Jun 18, 2015 10:59 PM
TheManOutside
Jun 18, 2015 03:32 PM
