94 V6 4Runner Spool Install?????
Old Dec 25, 2003 | 07:57 PM
customcruiser's Avatar
anybody know of a tech writeup on a Spool install (Yukon is what I got)
thanks
Old Dec 25, 2003 | 09:08 PM
Napoleon047's Avatar
its exactly the same as the install of any other locker or lsd that replaces the carrier i.e. detroit locker, supra lsd, truetrac, ARB(much simpler, although), etc
you will need to:
disconnect the rear brake lines, including e-brake cable
remove the 4 bolts on each side and slide out the axle shafts
disconnect the driveshaft
remove the 3rd member bolts
pull the 3rd member(its heavy, be careful)
now, i assume you have never set up a diff before, since you are asking this question. since you are replacing the carrier completely, i recommend that you take the 3rd member to a reputable diff shop and have them install it to make sure the proper preload and backlash is set up.
after that, the installation is reverse of removal.
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
bryan34w
Jul 6, 2015 05:53 PM
