87 Turbo runner, doggy power
Old Oct 22, 2005 | 10:08 AM
redvalkyrie's Avatar
You're in Sallisaw? Do you know a John Randolph?
Old Oct 22, 2005 | 12:04 PM
kyle_22r's Avatar
the stock turbos weren't the greatest units. they wore out pretty quick(most under 100k from what i hear) and are very expensive to rebuild/replace. i think the popular replacement/upgrades are the turbo from a later model supra, or a garrett t3.
Old Oct 22, 2005 | 12:46 PM
colsoncj's Avatar
Red, the name sounds familar but I cant place it... I've only lived here off and on for about 9 months.
Kyle, whats involved switching to a T3?
Old Oct 22, 2005 | 06:10 PM
He the son of Charlie from Charlie's Chicken.
But anyways, if you suspect the turbo you can buy a rebuild kit and rebuild it yourself. There is really nothing to it. I could lend a hand if needed.
Or, you could drop it off at Thompson Diesel in Tulsa and have them rebuild it.
Old Oct 22, 2005 | 09:38 PM
  #25
colsoncj's Avatar
Hmm... isnt ringin a bell... may take you up on that offer red.... but i wouldnt think it to be that hard either. do you have a rig you take wheelin? you could join us sometime when we go. always looking for more people to join.
Old Oct 22, 2005 | 09:41 PM
  #26
colsoncj's Avatar
Red, do you live in sallisaw?
Old Oct 23, 2005 | 12:44 AM
  #27
vwfastg60's Avatar
Well if you are only getting 3-4 bars on the dash then your not getting anything for boost.My truck with 7 psi will almost pin the lights 10 psi will pin them 1/2 way through the gear. Im guessing cracked or blown turbo/boost leak.check the gasket that comes out of the compressor and in to you pipe that thing has broken once on mine already also check out the rubber piece that s on the end that connects it to the t-body. mine at 200k has been replaced once cause they dry out and crack.Mine happened on the bottom....looked for hours to find the leak and when i found it i replaced it with a samco piece i had layin around.Pull the pipe off and check blow by with the turbo also pull the pipe off that goes to the mas air and check for shaft play.Im guessing that turbos done for. the other thing you might look at IF theres no blow by no shaft play and the housings not cracked then make sure the wastegates opening. if you have any kind of aftermarket cat back or muffler im sure you can hear it cause even stock oost mine sounds like a jet.If everything there checks out ok (my money says you found it already)then i would try O2 or mas air. Do you have a boost gauge? If you can get your hands on one even to ziptie in for a quick run i would try it its like a 2 second install and easy to remove. my turbo stock before i messed with the wastegate was at 8psi and 9ish on colder nights now im getting 10 in the heat and 13 in the cold with spikes when the truck shifts(auto).
if you have more trouble feel free to shoot me an IM me. Good luck with the runner.....and just wondering what you will be asking for it when its running again,Im a chicken sh!& and am scared to mod mine lol
my turbo
Old Oct 23, 2005 | 02:28 AM
  #28
Actually, I'm in Broken Arrow and am completely new to offroading. I've owned two MR2s for about seven years now and have just started getting the 4Runner itch.
Old Oct 23, 2005 | 08:49 AM
  #29
colsoncj's Avatar
VW, probably ask 2800ish for it.
Red, I know where a nice pickup down here is that is for sale... 84 ext. cab flat bed, new paint, 79 running gear, solid front axle, no rust anywhere, frame's been off for cleaning and painting, new paint on the cab, runs great, 35's asking 2500.
Old Oct 23, 2005 | 10:57 AM
  #30
I'm kinda holding out for a original 1st gen 4Runner but...if you have any contact info I'll certainly take a look. Sounds pretty nice.
Thanks
Old Oct 23, 2005 | 12:00 PM
  #31
colsoncj's Avatar
The guy is movin tuesday, so youd have to be quick... number is 918-774-0878. I'll keep an eye out for a first gen 4runner for ya too... i come across a lot of them, between my mom and i, in the last year we've owned 4 of them. still got 3. also had several 1st gen pickups... anything in particular you're lookin for?
Old Oct 23, 2005 | 05:55 PM
  #32
ironroad9c1's Avatar
yea you can get rebuild kits for these CT-20's on ebay for around 100 bucks ,i got lucky and found a used TEC kit ,got it for cheap ,but i need to rebuild the turbo and get a fitting for the oil and a oil return line and i'm gonna slap it on
Old Oct 23, 2005 | 06:40 PM
  #33
tulsa_97SR5's Avatar
Hey Cory, keep an eye out for me too! I've decided the 97 is too nice to mod or wheel too much.
Old Oct 23, 2005 | 07:09 PM
  #34
colsoncj's Avatar
No problem Brian! Let me know what options you guys are lookin for, and i'll see if i cant round something up for ya!
Old Oct 23, 2005 | 07:13 PM
  #35
Wow, that's awful nice of you. A 1st gen 4Runner with a 22RE and manual tranny would be right up my alley.
Old Oct 23, 2005 | 08:02 PM
  #36
colsoncj's Avatar
anything to help a local fellow yotatecher!
Old Oct 24, 2005 | 03:26 AM
  #37
vwfastg60's Avatar
Hey TEC is about an hour from my house(golden CO right?) if you want i can try to set up an account with them and get the parts cheaper.i know if you give them your tubo they will rebuild it for like $400 or i still have to check around but i was told theres a guy selling t3 super 60's for 300 new and there bearing turbos im going to call tomorrow for one for myself.Now that my motors bored and the head works done my truck is kinda starved for boost.and the stock ones working way to hard.I will let you know if i can get more i would be willin gto share that deal if people are interested in them...just have to pay shipping
Old Oct 24, 2005 | 04:02 AM
  #38
Yeah, Cory's a good guy. 4cyl 5spd here too, preferrably rough & cheap. Looking for a winter project.
Red, not sure what you're looking to spend, but there's a pretty decent looking one for 2500 in OKC listed on autotrader. I have some additional pics they emailed me a few months ago that I can forward if you want. They had it listed at 3000 then. They may be willing to haggle since it's been listed so long.
I'm tempted to fly up to philly & get that 85 that's for sale for $850, just concerned about all the rust on the frame.
Old Oct 24, 2005 | 05:17 AM
  #39
colsoncj's Avatar
Red and Brian, I'll keep my eyes posted for ya guys!
VW, what does TEC T3 Conversion kit run, any idea?
Old Oct 24, 2005 | 05:27 PM
  #40
all i need is the rebuild kit ,the fitting for the oil line and the oil return line and i'm set ,if you could see what you could do for me on that .also i bought a 94 VR6Passat for 500 bucks ..lol
